i took of my front left flare this morning to have a look at what iam going to need to do. with the flare off there is a L bracket spot welded all the way around that the flare bolts onto.
Do i cut off the spot welds holding on the L bracket so i can cut and bend?
well nev iam going to give mine a couple runs to see if its needed. if it needs it i dont see any dramas as i work next door to panel beaters who have all the tools needed.
Users browsing this forum: Google [Bot] and 279 guests
