| G16b wiring help https://auszookers.com/forum/viewtopic.php?f=5&t=18969 |
Page 1 of 2 |
| Author: | barney7779 [ Wed Feb 09, 2011 8:18 am ] |
| Post subject: | G16b wiring help |
Hey guys Doing the G16b conversion at the moment and need some help with the wiring Anyone got a diagram for a 97 Vit with the 3 wire air flow and mitsu computer. Computer has 2 blue plugs on it Better still anyone know how to do it that lives close to penrith that could come give me a hand for a few hours one night or on the weekend would be great. If i can get the right diagram for it then i will have a go but i dont want to stuff anything up Cheers |
| Author: | lumpy_zook [ Wed Feb 09, 2011 8:24 am ] |
| Post subject: | Re: G16b wiring help |
basicly the same set up that i have. any help would be great! im in the same situation myself.. |
| Author: | buzbox [ Wed Feb 09, 2011 8:34 am ] |
Looking at the wiring diagram in the workshop manual I have here, It looks like a mess but If i can beat my scanner into life I'll post them up. |
| Author: | barney7779 [ Wed Feb 09, 2011 8:48 am ] |
buzbox wrote: Looking at the wiring diagram in the workshop manual I have here, It looks like a mess but If i can beat my scanner into life I'll post them up.
That would be great, If that dont work any chance i would be able to borrow your book so i can sort the giant spagetti mess out |
| Author: | mondo [ Wed Feb 09, 2011 8:54 am ] |
i was in this boat a little while ago, i just looked at the wiring and HOLY F%$. i ended up draping the wiring loom on top of the sierra, getting it to start, then slowly picking apart the loom, once i was happy with the amount i had removed, i spliced it into the sierra loom, 1 step at a time and make sure it still starts!!! have you made your vss yet? |
| Author: | buzbox [ Wed Feb 09, 2011 8:56 am ] |
Just doing the final steps of installation. should be done in a sec, If I can't you can come down and I'll have it photocopied for ya. |
| Author: | barney7779 [ Wed Feb 09, 2011 9:01 am ] |
Mondo- Got the vit cluster so just have to remove VSS from it and fit to sierra speedo Buzbox- You are a champ |
| Author: | buzbox [ Wed Feb 09, 2011 9:11 am ] |
Now I just need to find out how to upload pdf files, or pm me your email address and I'll send it to ya's. |
| Author: | barney7779 [ Wed Feb 09, 2011 9:18 am ] |
buzbox wrote: Now I just need to find out how to upload pdf files, or pm me your email address and I'll send it to ya's.
PM sent |
| Author: | buzbox [ Wed Feb 09, 2011 9:21 am ] |
emailed.. |
| Author: | barney7779 [ Wed Feb 09, 2011 9:26 am ] |
Cheers mate Might help me out of trouble a little bit |
| Author: | lumpy_zook [ Wed Feb 09, 2011 9:38 am ] |
is htere any way of ditching most of the loom and just running the main engine harness? just powering the ecu and getting the tacho signal? i dont want to mess around with cluster or body loom swaps, and on closer inspection my vitara loom isnt complete. |
| Author: | atari4x4 [ Wed Feb 09, 2011 9:38 am ] |
you can attach pdf's via the attachment function on the forum |
| Author: | buzbox [ Wed Feb 09, 2011 9:41 am ] |
I'll give it a try.. But check out zookernators write up thread. http://www.auszookers.com/index.php?nam ... ng+diagram He got his diagrams from www.suzukiinfo.com |
| Author: | buzbox [ Wed Feb 09, 2011 9:49 am ] |
Haynes manual wiring diagrams for g16b Sidekick/Tracker |
| Author: | lumpy_zook [ Wed Feb 09, 2011 9:57 am ] |
only problem with zookinators write up is that he doesn't really explane the wiring, its just, 'started with this, ended with this' the pdf's you put up are good! thanks for that. now to try to decifer it all... can anyone explane the go with the distributers on this model? (with the two blue plugs on the ecu) it seems like the coil is built into the dizzy, as it only has 4 leads coming off the cap. |
| Author: | royce [ Wed Feb 09, 2011 10:16 am ] |
lumpy_zook wrote: is htere any way of ditching most of the loom and just running the main engine harness? just powering the ecu and getting the tacho signal?
i dont want to mess around with cluster or body loom swaps, and on closer inspection my vitara loom isnt complete. youll need a lot of room and some patience, pull the sierra loom out and lay it out on a flat surface in the same fashion as it sits in teh car so its easier to picture where it all is Get the vit loom and cut all the tape off and combined with a wiring diagram for the vit find all the wires that go from the ecu to teh engine, then figure out what all the wires that go from the ecu to somewhere else go and either splice them into the sierra loom or not use them (stuff like AC signals) then there will be some of the original sierra engine wires youll need to sort out, alternator wires, starter wires, oil pressure and temp etc Its piss easy to do if you take your time and work logically, if wiring isnt your strong point you are probably better of finding somebody on here that can take your looms and splice them and send it back |
| Author: | mondo [ Wed Feb 09, 2011 10:16 am ] |
yea this dizzy has the coil and crank angle sensor built in, it should have 7 pins on the plug to the distributor? mine was a 96 model, mitsu comp as well but mine had yellow plugs |
| Author: | lumpy_zook [ Wed Feb 09, 2011 11:55 am ] |
sweet, yea, thats the same one.. at least i can keep all the electrics dry in the same spot thats what im doing atm, its all laying out on the floor, or what i have anyway. will see how i go. any clues to where to patch into for power feed, or any tips? thanks |
| Author: | coneykid [ Wed Feb 09, 2011 7:16 pm ] |
here are two stand alone engine harness diagrams, thats all you need to make them run. |
| Author: | lumpy_zook [ Fri Jun 17, 2011 2:50 am ] |
just checking back here. wiried my loom up to test the motor before final fitment, and nothing is happening. no spark or fuel from what i can see. my set up is as above in my previous posts. the distributor is all in one, coil etc. the ecu has two blue plugs. i have had no luck in finding a wiring diagram for this set up! can anybody help me out here? i cannot afford to pay someone to do a loom for me. but cant find the info to do it myself. |
| Author: | JrZook [ Fri Jun 17, 2011 3:29 am ] |
lumpy_zook wrote: just checking back here. wiried my loom up to test the motor before final fitment, and nothing is happening. no spark or fuel from what i can see.
my set up is as above in my previous posts. the distributor is all in one, coil etc. the ecu has two blue plugs. i have had no luck in finding a wiring diagram for this set up! can anybody help me out here? i cannot afford to pay someone to do a loom for me. but cant find the info to do it myself. Fuel pump prime? |
| Author: | lumpy_zook [ Fri Jun 17, 2011 3:56 am ] |
Pump is hard wired. Doesn't spark. All I need is a wiring diagram for the 97 model... |
| Author: | BenT [ Fri Jun 17, 2011 5:13 am ] |
lumpy_zook wrote: Pump is hard wired. Doesn't spark.
What wires have you connected into the Sierra loom? I would start by un-hard-wiring the pump and connecting it to the ECU fuel relay. |
| Author: | lumpy_zook [ Fri Jun 17, 2011 5:37 am ] |
its not connected to the sierra loom. the motor is set up in the car, and computer is wired in with power etc from the battery. i dont have a diagram to know what does what exacty, so iv wired what i can direct to a battery. i need a diagram to know what wire is what. |
| Author: | BenT [ Fri Jun 17, 2011 6:57 am ] |
Wires you should have connected: White wire -> battery - permanent power. Black and white wire -> ignition on wire in Sierra steering column. Black and yellow wire -> start circuit again in steering column Pink wire -> fuel pump Optional: Yellow wire -> VSS (vehicle speed sensor) Purple wire -> check engine light. Have a look at the wiring diagrams posted. They may not be exactly the same as yours, but they are all similar, and the same wire colours are used for the above connections on all looms (AFAIK) Ben |
| Author: | royce [ Fri Jun 17, 2011 7:50 am ] |
Is there black/blue that needs to be ignition power in a 1.6 as well or does the ECU take care of it? |
| Author: | Fatzook [ Fri Jun 17, 2011 7:57 am ] |
royce wrote: Is there black/blue that needs to be ignition power in a 1.6 as well or does the ECU take care of it?
Yes. |
| Author: | BenT [ Fri Jun 17, 2011 8:17 am ] |
lumpy_zook wrote: All I need is a wiring diagram for the 97 model...
Try this. Oh, and looks like I forgot the black/red permanent power wire to the main relay. |
| Author: | royce [ Fri Jun 17, 2011 8:21 am ] |
black red is another start signal, hook to black yellow |
