It is currently Wed Nov 04, 2026 9:49 am
Post Posted: Wed Feb 23, 2011 8:34 pm
the steering in my coily has suddenly developed tight spots, i jacked the front end up and it is definately coming from the steering box. Is this a common problem? if so can i fix it myself or would i need to get the box rebuilt?.
Richo
97 Coily 2" susp lift 2" body lift + more
Post Posted: Wed Feb 23, 2011 8:51 pm
Pull the shaft out between the fire wall and the box and try moving the steering uni by hand. One will probably be stiff.
Wd 40!
Post Posted: Wed Feb 23, 2011 9:09 pm
Pull the shaft out between the fire wall and the box and try moving the steering uni's by hand. One will probably be stiff.
Wd 40!
:wink: Yep.... Mine did that, but I put a new one in
Post Posted: Wed Feb 23, 2011 9:10 pm
Mine di the same aswell will be the uni on the shaft between the column an box
Post Posted: Wed Feb 23, 2011 9:45 pm
sierras don't have a uni there, we roll with a rag joint...
Post Posted: Wed Feb 23, 2011 9:55 pm
got a uni at the firewall end though
Post Posted: Wed Feb 23, 2011 10:44 pm
I forgot.. stocko sierra one uni boys..
I ran 2 uni's. but with pissed vit ps box.
Online
Post Posted: Thu Feb 24, 2011 6:47 am
Where it gets brake fluid dropped on it.
Time for a new steering shaft.
The uni's aren't really replaceable - they are pressed in and very hard to remove. I replaced the unis in the steering shaft of my Gwagen, but they are much bigger than a sierra uni.
Post Posted: Thu Feb 24, 2011 6:53 am
i got the complete uni for $75 brand new.
Post Posted: Thu Feb 24, 2011 8:07 am
I just oiled mine never happened again
I ran vit p/s with 2 unis aswell
Users browsing this forum: Google [Bot] and 157 guests
