It is currently Wed Nov 04, 2026 10:36 am
Post Posted: Wed Feb 23, 2011 7:57 am
I have a x90 g16b in my sierra that once its warm it goes from 1000 rpm down to nearly staling then goes back up to 1000rpm and back down again...
Could this be the airflow meter doing this or is it something else, by the its running the standard computer.
josh AKA Bazook
Post Posted: Wed Feb 23, 2011 8:12 am
check engine light working but not on?
first step like always, check for air leaks, check the adjustment of the tps, clean the air flow meter with electrical clean
mine has done that before but its only ever been idle high when you take your foot off the throttle then drop to idle after a few seconds
also try unplugging the IAC, will tell if its the ecu upping the speed or something else
Post Posted: Wed Feb 23, 2011 8:34 am
Check O2 sensor plug also..
Post Posted: Wed Feb 23, 2011 8:46 am
iac was the first to come off might see if the engine light shows something
josh AKA Bazook
Post Posted: Wed Feb 23, 2011 8:49 am
how many wire O2 is yours??
Post Posted: Wed Feb 23, 2011 8:50 am
4 sir steaky
josh AKA Bazook
Post Posted: Wed Feb 23, 2011 8:51 am
I think :oops:
josh AKA Bazook
Post Posted: Wed Feb 23, 2011 9:01 am
Pull the code's, if any & we can go from there..
wish I had a tech 2 :roll: live data is friggin awesome..
Vehicle: 4wd
Post Posted: Wed Feb 23, 2011 9:29 am
Is there a 4 wire o2? Or 1 or 2?
Watch out or you'll get sued.
Post Posted: Wed Feb 23, 2011 12:13 pm
If it's an X-90 g16 it should be a 4 wire O2.
Post Posted: Thu Feb 24, 2011 6:44 am
1 & 4, the 4 wire has a heater for cold start's..
1 has one wire... :wink:
Online
Post Posted: Thu Feb 24, 2011 7:14 am
Users browsing this forum: No registered users and 93 guests
