It is currently Wed Nov 04, 2026 3:16 am
Vehicle: Jimny, Lifted on 30's
Post Posted: Thu Feb 24, 2011 4:37 am
Getting some quotes on sunnrasia rims for my new 225 80 15s and a few places have said that as soon as you put bigger tyres on jimnys the steering starts shaking or something around 80 just checking if you have any problems with 15x7 rims and bigger tyres. I have a slight tyre shake but nothing to worry about aroun 70? Thanks guys!
Post Posted: Thu Feb 24, 2011 4:46 am
i have the same problem with mine. not 100% sure what the go in.
i've even put a steering damper made it better for awhile.
thinking of putting my sway bar back on :?
Yeah Cheers Kent~!
Post Posted: Thu Feb 24, 2011 4:53 am
when yours happens is it crazy shaking or is it just a small wobble and you can accelerate through it?
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Thu Feb 24, 2011 4:55 am
crazy shakes lol.
what model is yours.
Yeah Cheers Kent~!
Post Posted: Thu Feb 24, 2011 5:01 am
2009 non vvt running 215's
Post Posted: Thu Feb 24, 2011 5:02 am
what size tyres are you running?
Post Posted: Thu Feb 24, 2011 5:06 am
i thought they were all vvt engines after 2005
:blink:
Post Posted: Thu Feb 24, 2011 5:07 am
well i dont have a little vvt badge so i assumed it was a non vvt?
2005 jimny vvt
i was running 30's but now i'm back to standard tyres.
still does it abit though.
i'm going to take all my suspension out and bring it to standard.
see if that does anything, if not put the sway bar back on.
pretty sure i'm gonna sell it anyways.
i bought a sierra 8)
Yeah Cheers Kent~!
Post Posted: Thu Feb 24, 2011 5:09 am
ooooh yeah :P haha well good luck with it all zookfisher! i will just have to do it and see what problems come up!
Post Posted: Thu Feb 24, 2011 5:12 am
yeah no worries.
i think its probably worth investing in buying the "Full suspension kits"
for the jimny, as i only went shocks and springs.
this could also be the reason.
i'm not sure what you did though?
Yeah Cheers Kent~!
Post Posted: Thu Feb 24, 2011 5:15 am
Just went 2 inch dobinson coils and longer shocks.
Post Posted: Thu Feb 24, 2011 6:11 am
There is a lot of info about the wobbles in this thread. I have just bought a stabilizer and will be getting that and new bushes fitted.
Paul
http://auszookers.com/index.php?name=Fo ... bble+group
Post Posted: Thu Feb 24, 2011 6:37 am
Mid 09 the VVT was an all the range, so they stopped putting Vvt badge's on em..
before that if Vvt, it said so on the front guard's...
Post Posted: Thu Feb 24, 2011 6:55 am
aaaaaaaaah! Awesom i have a VVT!
Post Posted: Thu Feb 24, 2011 7:07 am
go get a pic of the front of you eng looking down at the fan, & I will tell you if Vvt or not.. :D
Post Posted: Thu Feb 24, 2011 7:10 am
you and i both know it will be..
Post Posted: Thu Feb 24, 2011 7:21 am
But I like pic's... :lol:
Post Posted: Thu Feb 24, 2011 7:24 am
Maybe i will take a picture tomorrow just to amuse you Stekky! Ill be sure to label the engine :P
Post Posted: Thu Feb 24, 2011 7:53 am
Sounds like the shakes could be to do with castor?
Putting a steering dampner on is just masking the problem. also check for worn components
Post Posted: Thu Feb 24, 2011 7:56 am
ok great thanks ! I rotated the wheels a few hours ago and it has reduced the shaking by 95%
Post Posted: Thu Feb 24, 2011 8:46 am
what prices did you get for rims mate?
Post Posted: Thu Feb 24, 2011 8:50 am
65 buks for black and another 20 for fitting :P just gotta save some cash to get them then ill be cruizin!
Vehicle: 06 Jimny
Post Posted: Thu Feb 24, 2011 8:52 am
After reading many tech threads and other posts about Jimny wobbles it seems that it is one of the wonderful design features that have been built in to the machine.
I have always had a wobble at 78K/hr I have found that this can be amplified into a death wobble with glutiness mud sticking to the rims. (Wail nursery Dimboola, standard rims and tyres).
Check for anything that can cause an unbalance, from mud, cold tyres, tyre pressures, to uneven wear. It seems the short wheel base and the rim/tyre size simply set up a bad harmonic. Any home remadies please tell me . :?
Post Posted: Thu Feb 24, 2011 8:53 am
I'm running 15x7's, i have the wobble but only started after a putting a RTC on.
Post Posted: Thu Feb 24, 2011 8:54 am
I have always had a wobble at 78K/hr I have found that this can be amplified into a death wobble with glutiness mud sticking to the rims. (Wail nursery Dimboola, standard rims and tyers).
Check for anything that can cause an unbalance, from mud, cold tyers, tyer pressures, to uneven wear. It seems the short wheel base and the rim/tyer size simply set up a bad harmonic. Any home remadies please tell me . :?
Paul
:D
