It is currently Wed Nov 04, 2026 10:37 am
Post Posted: Thu Feb 24, 2011 5:48 am
got some 31x10.5R15 muddies today for my sierra. they're on 15x8 rims with a -23 offset. 2" spring lift. will they go on with some guard massaging? or will the body lift need to come sooner?
Post Posted: Thu Feb 24, 2011 5:49 am
Lots of massaging and a body lift in the near future
Post Posted: Thu Feb 24, 2011 5:53 am
They will fit with no guard work (to speak of) if you fit a 2" BL.
Without a BL, yes, there will be guard work on the front.
Vehicle: 4wd
Post Posted: Thu Feb 24, 2011 5:57 am
Very little inner guard work required. Mainly folding of the seams.
Watch out or you'll get sued.
Post Posted: Thu Feb 24, 2011 7:14 am
Yep that's what I thought. Fold the seams. Not going to take it bush until I get the body lift in. Just to be safe. Just wondering if I'll be able to drive it around.
Post Posted: Thu Feb 24, 2011 7:24 am
Downwards, so no mud & shit will not get stuck in there causing rust..
Post Posted: Thu Feb 24, 2011 8:04 am
Fair call! Cheers.. I'm a little excited now.
Post Posted: Thu Feb 24, 2011 8:34 am
where did you go to get them tyres mate?
also can you put 31x10.5R15 on 7" wide rims?
Post Posted: Thu Feb 24, 2011 9:20 am
Tyrepower Gateshead (Newcastle, NSW). Great bunch of guys, 4wd dedicated tyre shop so they have a good range. Great help, good price. I believe they do fit on 7" but I am not 100%.
Post Posted: Thu Feb 24, 2011 10:38 am
yep :D no problems
Post Posted: Thu Feb 24, 2011 12:58 pm
Those tyres are recommended for 7 - 9 inch wheels
The main seem you need to found is on the fire wall running up the wall, just BFH it, theres also one running across fold that down.
Cleanest and easiest method of clearing big tyres is a BL however you can do a virtual lift if you are good with panels and bodywork. Me, the most bodywork I do is with the back of an axe or a lump of wood.
Vehicle: Daisy
Post Posted: Thu Feb 24, 2011 6:33 pm
This is good news, because with 2" spring and 2" bodylift, I won't have to do bugger all to run 31's!
Well, aside from getting new rims that will actually balance up...
Post Posted: Thu Feb 24, 2011 6:50 pm
Yeah, they definitely fit with a body lift. I've just gotta get the coin for one. And I pick up the tyres today and want them on now!!
Post Posted: Thu Feb 24, 2011 8:56 pm
BFW!
BFH, and possible bumps stop extension.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Thu Feb 24, 2011 9:09 pm
I have ~2" suspension lift, had to do the seams, +25mm bumpstops and 31x10.5R15 on 7" wide rims.
I also have narrow track spacing and am quite narrow overall, helps me keep up with the 35" guys as I can grab the inside of the ruts while they sit in them.
Post Posted: Thu Feb 24, 2011 11:12 pm
What's BFW AND BFH? Big fucking hammer?
Post Posted: Thu Feb 24, 2011 11:18 pm
BFW = Big Fk'n Wood?
Post Posted: Thu Feb 24, 2011 11:24 pm
yes :lol:
Post Posted: Fri Feb 25, 2011 2:03 am
My 31's fit on with no more than extended shackles, They do scrub on the leaf packs on full lock though.
Post Posted: Fri Feb 25, 2011 2:08 am
Mmm.. Not a huge fan on extended shackles as I want lots of flex.
Post Posted: Fri Feb 25, 2011 2:09 am
extended shackles wont limit your flex, i am not a fan either but not for that reason
Post Posted: Fri Feb 25, 2011 2:19 am
They are not ideal (you can see them tyring to twist when flexed up) but it's not a daily driver. and I'm only running standard Rear leaves all round at the moment.
Users browsing this forum: No registered users and 114 guests
