| GV Front Struts https://auszookers.com/forum/viewtopic.php?f=5&t=1946 |
| Author: | ZX1990 [ Thu Apr 10, 2008 1:28 pm ] |
| Post subject: | GV Front Struts |
I'm looking at upgrading the front struts - the stockies are topping out a bit with the coil spacers - not badly, but I don't think they are going to last long Any recommendations on brand? And prices? I have one quote of $325 delivered for a pair of Lovells Gas legend +25/30mm lift off 4WD Direct.... Cheers |
| Author: | TheOtherLeft [ Thu Apr 10, 2008 4:16 pm ] |
| Post subject: | Re: GV Front Struts |
The general consensus is that OME struts are the best as they are 40mm longer, as oppossed to standard length struts with extended shafts welded on. |
| Author: | Bruce [ Thu Apr 10, 2008 9:38 pm ] |
yep can't go past OME ones. You can also do a strut mount flip. |
| Author: | ZX1990 [ Fri Apr 11, 2008 12:24 pm ] |
OK - I'll have a look round to get some OME ones - and I thought you couldn't do the strut top flip on the GV? Would give you the same effect as strut extenders thoughI guess - ie less compression...may be worth a look though... |
| Author: | sp1086 [ Fri Apr 11, 2008 7:01 pm ] |
YEah OME or Tough Dogs both around the same price.. both 2 year warrenty. If you get the Tough Dogs they supply a pair of camber pinns to re adjust that wheel angle.. OME you'll need to go get a set from say pedders and they are around $120.. |
| Author: | ZX1990 [ Mon Apr 14, 2008 12:19 pm ] |
Sweet.... I'll get a few prices today and see whats round, I've already got the camber pins - after the lift I was pretty scared by the positive camber |
| Author: | ZX1990 [ Mon Apr 14, 2008 2:58 pm ] |
Just got a few prices - OME come in at $440 for the pair - does that sound like a reasonable price? Need them for this weekend..... Cheers! |
| Author: | ODA1 [ Mon Apr 14, 2008 3:21 pm ] |
sounds allright but for this weekend i dought it as they dont keep GVstuff in stock |
