It is currently Wed Nov 04, 2026 7:19 pm
Vehicle: Vitara
Post Posted: Fri Feb 25, 2011 8:38 am
Hey guys so I'm having an intermittent fuel cut issue.
I will be driving alond fine, will stop the car for a period longer then say 5 minutes and (sometimes) it will get 5 mins of driving and die(no fuel in the bowl of the carby)
I've replaced the carby, checked the lines for blocks and replaced my fuel filter yet its still doing it.
Could this be a fuel pump issue? How would I check and why would it only happen sometimes and not other?
Any help that would steer me in the right direction would be awesome..
Ron
**Also after just having it happen again on teh highway, its seems its ok to drive in 1st or 2nd till around th 3,00RPM mark but if i go up gears it dies..
I have a Nikki Datsun carby on there at the moment(which when runnign runs amazingly well) which has a large Fuel level window on the front and its clear that the fuel is near emty in the bowl/window..
Repping it, High Top style!
Post Posted: Fri Feb 25, 2011 8:41 am
Pull the out line off the pump and crank the motor. I betting on a dying fuel pump
Vehicle: Sj70 tintop
mate its those crafty beenleigh theives!!!
Sj70 tintop
Post Posted: Fri Feb 25, 2011 8:51 am
but in all seriousness ron, i had this problem in my old lwb, i replaced the fuel pump, re kitted the carby and drained and cleaned the tank, went well for 10 minutes and did the same as yours again, blew some compressed air down the return fuel line (hooked up the nozzle to the line where the metal starts) gave it a squeeze and could smell fuel straight away,
had a very small hole in the rubber feed line from the tank to the carby, would only be a problem above 3000rpm, because the fuel pump is cam driven and only sucked hard enough to be a problem above 3000rpm
the reason being the pump finds its easier to suck air than fuel and thus cuts your fuel supply.
replace all your rubber hoses from the tank to the carby (costs bout $11 including new hose clamps) than id that doesnt sort it i would call it the fuel pump ($115 ish brand new)
also i had an old hr that used to do similar things, the jet in the holley was to big and flooded it, but this was when gearing down with no load, not gearing up.
hope this helps.
Sj70 tintop
Vehicle: Vitara
Post Posted: Fri Feb 25, 2011 8:54 am
haha First thing i checked was my fuel cap was still there :P..
I was thinking fuel pump but it seemed to pump fine when I was playing with the new carby while putting it on..
will try Hoses and pump tomorrow and see how I go..
Thanks Heaps guys..
Ron
ill send you a perfectly working fuel pump for $20+postage...........
i went efi.....
PM me if your keen, i forget to check threads :lol:
Vehicle: Vitara
Post Posted: Fri Feb 25, 2011 8:57 am
pm Sent :D
Post Posted: Fri Feb 25, 2011 9:00 am
Thanks Heaps guys..
Ron
let me know how you go!
if im right,
this will validate me as useful contributer on here instead of just a gobby little c$%T
Sj70 tintop
Vehicle: Vitara
Post Posted: Fri Feb 25, 2011 9:04 am
haha Noted... however now i know that i might just say it wasnt just to be a Kent and deny you validation :P lol..
Will see how i go and get back to you lol
Ron
Post Posted: Fri Feb 25, 2011 9:18 am
or u cant cause some one stole ya keyboard/computer/house
:blink:
Sj70 tintop
Vehicle: Vitara
Post Posted: Fri Feb 25, 2011 9:20 am
or...
Maybe I'm the one who doesnt have a keyboard/computer/house and I'm in someone elses house using theirs
:lol:
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Fri Feb 25, 2011 9:33 am
I have a coily with a weber and it runs great
Oh you have a Nikki Datsun carby on there... How cute :p..
I have issues
What are you looking at
Post Posted: Fri Feb 25, 2011 9:43 am
mr_ron wrote:
or...
:lol:
or the pcyc has a communal computer you use between servings of soup?? :lol:
Sj70 tintop
Post Posted: Fri Feb 25, 2011 10:41 am
If it's intermittent it may be a thingy in ya tank floating around and sometimes blocking the pipe.
I had the little bit of plastic out of the lid of an additive in a diesel tank once, would sometimes drive 100's of k's without problems....sometimes meters.
bye
Post Posted: Fri Feb 25, 2011 10:53 am
bye
:D I like this one..............
Vehicle: Vitara
Post Posted: Fri Feb 25, 2011 3:01 pm
Pcyc Has soup?! I'm so there! :lol:
I will drain the tank and check lines.. have a 'new' fuel pump on the way...
haha yeh I have a Holley 180 Twin throat to go on but dont want to put it on until I sort out what my fuel suppy is doing...
to break a 'cute' Datto carby is no real bother.. to break a fully rebuilt dual throat 180 Holley would pi$$ me right off :P lol..
Ron
Post Posted: Fri Feb 25, 2011 5:18 pm
deep throat ..... lolz
Sj70 tintop
Post Posted: Fri Feb 25, 2011 5:19 pm
god damn it just saw it said dual throat.......
Sj70 tintop
Post Posted: Fri Feb 25, 2011 8:28 pm
How confident are you it's fuel?
On other cars (not sierra) the ignition module in the dizzy once it got warm wasnt working and would cut out. removing it, new thermal paste and bolt back down solved it.
I would also drop your fuel like cairnsbye said
Post Posted: Fri Feb 25, 2011 8:50 pm
he has window in the bowl, can see it empty...
Post Posted: Sat Feb 26, 2011 12:03 am
:oops: :oops: :oops:
Post Posted: Sat Feb 26, 2011 2:11 am
Dropping the fuel may not help, i did that.
As a last resort I took the tank out and turned it upside down...out came this bit of plastic.
bye
Vehicle: Vitara
Post Posted: Sat Feb 26, 2011 5:14 am
Dropped my fuel.. Checke dthe tank and its amazingly clean inside as was the fuel :D lol..
Replaced the Lines, Went better revved over 3k for a change (;) thanks Joel)
Still had fuel issues, Took the Fuel pump off and the internal seal was roooted and it was filling with oil.. :s
Replaced the Fuel pump with an External fuel pump and ran new lines..
Runs good as gold.. Next step is to get me a smokey motor and rebuild it and replace mine...
Problem solved.. (I hope!!)
Thanks for the info guys helped me a lot!
Ron
Users browsing this forum: No registered users and 157 guests
