It is currently Wed Nov 04, 2026 10:37 am
Post Posted: Sat Feb 26, 2011 3:00 am
Hey,
So im installing gears in my transfercase, how do I undo the bolts on the driveshaft flanges? The instructions say they are 28mm.. Does one of the flanges need to be held with some kind of vice? Cause it just spins around and I cant find anything to help stop that...
Thanks guys
Post Posted: Sat Feb 26, 2011 3:05 am
use this and a breaker bar, or a rattle gun ;)
Post Posted: Sat Feb 26, 2011 3:06 am
I believe there is a flange removal tool it's just a bar with two studs that u slip in the bolt hole while you undo the center nut or you could just try get it in the vice
F#%ING [P] PLATER
 Profile YIM
Post Posted: Sat Feb 26, 2011 3:07 am
Haha beat me to it 31zook
F#%ING [P] PLATER
 Profile YIM
Strong Rattle gun and socket
or
Vice
Spanner + hammer
Possibly Heat to loosen it up.
Post Posted: Sat Feb 26, 2011 3:15 am
94BAZOOKA wrote:
flange removal tool
thats exactly what i googled :lol:
Post Posted: Sat Feb 26, 2011 3:16 am
Cheers everyone!!
More tools added to the shopping list!!
Post Posted: Sat Feb 26, 2011 5:01 am
flange in the vice, socket to suit, rattle gun and try and pry out the indents in the nut that are there to stop it spinning.
Go hard,
Post Posted: Sat Feb 26, 2011 5:12 am
i just put on a welding glove and held on tightly while upping it with a rattle gun.
Post Posted: Sat Feb 26, 2011 5:21 am
I dont got air tools, I gotta make my face turn blue on these kinda situations...
Also with installing the 6.5's, will this make my speedo as accurate as it was when stock?
Post Posted: Sat Feb 26, 2011 5:37 am
it wont make a difference to your speedo mate
Vehicle: LWB Sierra & XL7
Post Posted: Sat Feb 26, 2011 5:40 am
shane1992 wrote:
I dont got air tools.
You can bring it over mine, I've got a decent bench vice but my garage is a shit tip at the moment or I'll bring my compressor and gun over to yours. :wink:
It shouldn't take long.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sat Feb 26, 2011 7:01 am
Two bolt hols and bolts in a peice of RHS or angle = custom flange tool.
works a treat. Clamp it to your bench or stand on it, slip another peice of steel on your socket and your laughing.
I had one that the rattle gun wouldnt do, but the bf breaker bar did, great big crack when it went.
And Im pretty sure they are 27mm not 28. Just tap out the indents with a slim center punch first.
Post Posted: Sat Feb 26, 2011 8:24 am
Been trying all arvo, Broke some shit in the process too.
Yeah Dave I think I am going to have to take you up on that offer!! Whatevers easier for you
Post Posted: Sat Feb 26, 2011 9:02 am
a peice of flat bar with two bolt in at the right spacing is just and good and cheaper
Post Posted: Sat Feb 26, 2011 9:28 am
Yeah had my mate stading on tansfer case with 2 bolts in and crow bar wedges in, It just bent my drive shaft bolts ay lol, Needs a rattle gun I think. Very stubbrn
Post Posted: Sat Feb 26, 2011 3:44 pm
/\ This /\ is good advice. Just don't use a cheap pikc or screwdriver to pry out the indent, it will break off, and pinned the nut on there even harder.
I learned the hard way, and had a broken off tip of a screwdriver in there holding it solid. :oops:
Users browsing this forum: No registered users and 113 guests
