https://auszookers.com/forum/
OME lift
https://auszookers.com/forum/viewtopic.php?f=5&t=19519
Page 1 of 2
Author:  Fity [ Sun Feb 27, 2011 1:10 am ]
Post subject:  OME lift
I am considering an OME spring lift for my Sierra and I want to know if anyone who has one can tell me the thickness of the leaves (probably 5 or 6mm or both) as ARB can only give me an overall pack height. I am after a nice soft ride. Thanks.
Author:  SuziBlu [ Sun Feb 27, 2011 1:28 am ]
Post subject:  Re: OME lift
OME comfort pack, softest riding springs out, on suziblu, rear spring, right next to the shackle, 6.5mm
Author:  Vash [ Sun Feb 27, 2011 2:35 am ]
Im thinking of going OME but a mate says they're shit and to go lovely springs & bilstein shocks. what ya's reckon
Author:  SuziBlu [ Sun Feb 27, 2011 2:44 am ]
I must be biased, OME every time.
Author:  atari4x4 [ Sun Feb 27, 2011 3:58 am ]
where do you get lovely springs from? :?
Author:  SuziBlu [ Sun Feb 27, 2011 3:59 am ]
Love shack.
Author:  joel [ Sun Feb 27, 2011 4:51 am ]
what absorbers match up really well with the ome springs?
Author:  SuziBlu [ Sun Feb 27, 2011 4:54 am ]
Get the OME kit, they supply shockies as well. Very well mated to the whole thing, no guess work.
Author:  christover1 [ Sun Feb 27, 2011 5:09 am ]
I had OME on my Sierra for 12 years, best thing I ever did.
Now got OME on my Vitara, still happy.
can't really vouch for springs now, as they not made in same place.
Author:  ajsr [ Sun Feb 27, 2011 5:51 am ]
Ive had ome and rancho, and the ome have been great
Author:  mr_ron [ Sun Feb 27, 2011 6:21 am ]
What do you guys think of the Rockcrawler or calmini leafs?
Author:  JrZook [ Sun Feb 27, 2011 10:44 am ]
OME's are 6mm. Ride well but are a bit on the short side.
Dan
Author:  Fity [ Sun Feb 27, 2011 10:41 pm ]
Dan
Are all the leaves in the pack 6mm? Short springs? Are you referring to the lift or the length of the main leaf?
Author:  JrZook [ Sun Feb 27, 2011 11:22 pm ]
Fity wrote:
Dan
I know the main is for sure, because i copied the thickness and im very sure the rest of the pack it too. Besides the load bearer. Stock spring packs are also made of 6mm leaves
Author:  SuziBlu [ Sun Feb 27, 2011 11:49 pm ]
Dan
I dunno about short, I recon as they are longer than OEM, as the shackles are now near flat with the chassis, I recon as ride could be improved a bit by getting an inch longer shackles.
The ride is so far superiour to that of OEM that im not bothered, and as suziblu is becomig a donor, I recon as the rears off her will go to the front of my maruti.
Author:  JrZook [ Mon Feb 28, 2011 12:26 am ]
SuziBlu wrote:
Dan
Sounds like you have a one off set then or another OME spring type. All teh OME dakars ive seen (med and heavy duty) are only like ~10mm longer in the mains than a stock rear spring
Author:  matfan [ Mon Feb 28, 2011 12:28 am ]
What is a set of OME's worth?
Author:  JrZook [ Mon Feb 28, 2011 12:29 am ]
Around $400 for a set of front and rear springs from ARB
Author:  SuziBlu [ Mon Feb 28, 2011 12:30 am ]
Yea dunno. I know when I rang and spoke to them, they asked a ton of questions.
They wanted to know what my driving style was, where I wheeled, my weight, would I have passengers as norm, often, now and then, what would normally be in the back, al sorts so as to get the right springs for me, and I am ever so happy with what they sent.
Im around 130kg, and 3 years of fairly constant driving, no suzi lean, says a lot.
Author:  xedent [ Mon Feb 28, 2011 7:15 am ]
hey buddy did you get the dakar ones ?
Author:  abclarke [ Mon Feb 28, 2011 8:46 am ]
Is that just for the springs? What else do you need for the lift? Because if i was thinking of spending the $200 or so on the body lift i might as well get these if they are better and close to the price (and id get the right amount of lift for the 31's?)
Author:  xedent [ Mon Feb 28, 2011 9:05 am ]
From what i have read probably need 2" susp and body lift also.
Author:  abclarke [ Mon Feb 28, 2011 9:21 am ]
dammit :(
Author:  303zuke [ Mon Feb 28, 2011 9:39 am ]
This is the current ARB pricing, decide what else you need to complete your install:
Author:  xedent [ Mon Feb 28, 2011 10:38 am ]
thanks for that 303zuke, what does it mean by to 25kg ?
I got the shop to order some in today for my maruti and he is ordering in the soft ones ?
Are they recommended ?
Author:  abclarke [ Mon Feb 28, 2011 10:47 am ]
303zuke thanks for the prices, but i really have no idea where to start... I might jsut have to swing by one day and ask them?
Author:  JrZook [ Mon Feb 28, 2011 11:09 am ]
Well you will need:
Springs
Spring bushes
New u-bolts are reccomended
Longer shocks to maximise the extra travel
For 31's a spring lift alone will not clear them properly. Simplest way is to also add a 2 inch body lift + flatten all the wheel arch seems and possibly extend the bumpstops.
IMO for only an extra overall diff clearance gain of 1 inch and the amount of work involved to clear them you may be just better off with 235/75 tires (29"). They will fit with seem flattening and just triming the front bumper mount.
Dan
Author:  abclarke [ Mon Feb 28, 2011 11:18 am ]
JrZook wrote:
Well you will need:
Springs
Spring bushes
Dan
Thanks for the info JrZook. Yeah i think that might be the cheapest option in the mean time till i flog off the commodore!
I cant seem to find any info on flattening out the seems, do you have a link to anything at all?
Cheers,
Aaron
Author:  SuziBlu [ Mon Feb 28, 2011 6:42 pm ]
Thats the ones, lovely things.
Author:  JrZook [ Mon Feb 28, 2011 8:47 pm ]
To me they sound like customs from OME. From your description they seem to be wayyy longer than what the rest of us got off the self
Page 1 of 2 All times are UTC + 9:30 hours
