| might needa re-build https://auszookers.com/forum/viewtopic.php?f=5&t=1955 |
| Author: | norm [ Sat Apr 12, 2008 3:46 am ] |
| Post subject: | might needa re-build |
ok ppls, i think i might need a re-build on my lil beast, which sucks ass!! this may sound dumb, but how do you know when a engine is on its way ATM it blows alot of smoke on boost and a lil on idle. when i got the car, it had 2 holes drilled on top of the rocket cover with hoses running to a over flow as well as another hose comming from the original breather. it also had a blown rocket cover gastket, so i chaned the gastket and decieded to replace the cam cover as it seemd dodgy that there were 2 holes on it. THEN the smoke begun so therefore, rings might be gone.. SO dose anyone know a good/cheap rebuilder. im in west sydney/ penrith. the car still drives and will still take it 4wd |
| Author: | royce [ Sat Apr 12, 2008 4:53 am ] |
| Post subject: | Re: might needa re-build |
its turbo isnt it? could be pretty normal, G series engines suck for blow buy and oil burning so sounds like they were trying to stop that turbo could be on its way out too, is it very oily? |
| Author: | sp1086 [ Sat Apr 12, 2008 10:48 am ] |
Yeah the turbo could be sucking the oil up through the breather hose and then your just burning it up. |
| Author: | Pubic [ Sat Apr 12, 2008 11:12 am ] |
i have a gti motor for sale, its missing a the throttle body, but if you already have one then there is no drama it has EFI written on top, i think this identifies it as a MK 2. the MK1 had EPI (electronic petrol injection) MK2 had EFI (elctronic fuel injection) MK3 was blank. or so i read somewhere. i had $200 on it but am willing to take $150. i was told there was a big end bearing noise. i havent pulled it apart to find anything wrong with it so i dont know. pm me if you want it |
| Author: | norm [ Sat Apr 12, 2008 6:43 pm ] |
sp1086 wrote: Yeah the turbo could be sucking the oil up through the breather hose and then your just burning it up.
yhe thats was the other thing i though of. as it still pulls hard |
| Author: | norm [ Sat Apr 12, 2008 6:45 pm ] |
Pubic wrote: i have a gti motor for sale, its missing a the throttle body, but if you already have one then there is no drama
it has EFI written on top, i think this identifies it as a MK 2. the MK1 had EPI (electronic petrol injection) MK2 had EFI (elctronic fuel injection) MK3 was blank. or so i read somewhere. i had $200 on it but am willing to take $150. i was told there was a big end bearing noise. i havent pulled it apart to find anything wrong with it so i dont know. pm me if you want it nah its its cool pubic, if i were to do anything id rebuild this one as its only the 1.3 head the rest is vitara.. |
| Author: | Pubic [ Sat Apr 12, 2008 7:44 pm ] |
are the blocks them same in the vitara and sierra??? one for royce??? |
| Author: | Scrawny [ Sat Apr 12, 2008 8:22 pm ] |
norm wrote: it also had a blown rocket cover gastket, so i chaned the gastket and decieded to replace the cam cover as it seemd dodgy that there were 2 holes on it. THEN the smoke begun
I'm guessing you mean the rocker cover gasket was leaking? Or do you mean the head gasket was blown? When you turbo a non-turbo engine, especially an old, worn one, you end up with lots of blow-by. Hence why the breather bottle is added on, to catch all the oil that gets spat out the breather. |
| Author: | norm [ Mon Apr 14, 2008 12:11 am ] |
ScrawnC wrote: norm wrote: it also had a blown rocket cover gastket, so i chaned the gastket and decieded to replace the cam cover as it seemd dodgy that there were 2 holes on it. THEN the smoke begun I'm guessing you mean the rocker cover gasket was leaking? Or do you mean the head gasket was blown? When you turbo a non-turbo engine, especially an old, worn one, you end up with lots of blow-by. Hence why the breather bottle is added on, to catch all the oil that gets spat out the breather. yes the rocket cover had a busted gastket, so i replaced that, since i had the rocket cover of already, i thought i would change it as it had 2 extra lines coming out of it into the catch can.. wich look prity shaby to me. so now i have only one line, which is from the original breather. as for its a being old engine, it was rebuilt by the previous owner, during the rebuild he increased the capacity from 1.6l to 1.7l. i took the old girl out today for some fun, blew smoke but not as much... could just be a tuning problem.. |
