| Vitara Body Lift https://auszookers.com/forum/viewtopic.php?f=5&t=19556 |
| Author: | stocker [ Mon Feb 28, 2011 5:32 am ] |
| Post subject: | Vitara Body Lift |
Ok. So the dude who sells the body lift on here, how hard is it to actually install his body lift (As i've never done one) , and will i need more than 1/2 a case of piss, along with a trolley jack, couple of planks of wood. spanners sockets the usual tools (including myself) |
| Author: | atari4x4 [ Mon Feb 28, 2011 5:36 am ] |
| Post subject: | Re: Facelift |
it's not that hard... 2 big bottle jacks are better than trolley jacks as they lift straight up rather in an arc like the trolley jack. the instructions are pretty easy to follow, read them through them a few times while looking at the parts described in the instructions, i've fitted the just cruisin' kit to my vit in a few hours, but having done one previously made it a bit easier. FYI, awesome thread title... will make it heaps good when someone else does a seach |
| Author: | stocker [ Mon Feb 28, 2011 5:47 am ] |
atari4x4 wrote: it's not that hard... 2 big bottle jacks are better than trolley jacks as they lift straight up rather in an arc like the trolley jack.
the instructions are pretty easy to follow, read them through them a few times while looking at the parts described in the instructions, i've fitted the just cruisin' kit to my vit in a few hours, but having done one previously made it a bit easier. FYI, awesome thread title... will make it heaps good when someone else does a seach :roll: Changed it
and cheers. i shall invest in one now Now just gotta get on to buckets case for his Calmini kit!!! |
| Author: | abclarke [ Mon Feb 28, 2011 6:00 am ] |
| Post subject: | Re: Vitara Body Lift |
Where abouts in sydney are you stocker? If its not too far ill help you with yours if you help me with mine when I get it |
| Author: | stocker [ Mon Feb 28, 2011 6:14 am ] |
Im based in Glenwood near blacktown *shudders* |
| Author: | Jasen [ Mon Feb 28, 2011 6:35 am ] |
atari4x4 wrote: it's not that hard... 2 big bottle jacks.....
I read that as 2 big bottles of Jack (Daniels) and thought jeez if i need that b4 a body lift i'm in trouble
| Author: | Bruce [ Mon Feb 28, 2011 6:39 am ] |
stocker wrote: Ok. So the dude who sells the body lift on here, how hard is it to actually install his body lift (As i've never done one) , and will i need more than 1/2 a case of piss, along with a trolley jack, couple of planks of wood. spanners sockets the usual tools (including myself)
So did you buy the bodylift kit from this so called dude? |
| Author: | stocker [ Mon Feb 28, 2011 6:46 am ] |
Bruce wrote: stocker wrote: So did you buy the bodylift kit from this so called dude? Yeppers... Its Justcruizin i forgot his username ahhahahahahaha 2 Bottles of jack and i reckon i would be pushing up daisys |
| Author: | Bucket [ Mon Feb 28, 2011 7:33 am ] |
I can probably come out and give you a hand if you need. Let me know when you plan on doing it, as I'm a bit stretched for cash, even fuel this week :s |
| Author: | stocker [ Mon Feb 28, 2011 7:39 am ] |
No drama's dude. I only ordered it today. i dunno how long he takes to ship etc... |
| Author: | shakes [ Mon Feb 28, 2011 7:57 am ] |
Bucket wrote: I can probably come out and give you a hand if you need. Let me know when you plan on doing it, as I'm a bit stretched for cash, even fuel this week :s
syphon out some fuel as payment when you get there |
| Author: | Bruce [ Mon Feb 28, 2011 7:58 am ] |
stocker wrote: Bruce wrote: stocker wrote: So did you buy the bodylift kit from this so called dude? Yeppers... Its Justcruizin i forgot his username ahhahahahahaha 2 Bottles of jack and i reckon i would be pushing up daisys Well all the instructions would have come with the kit so follow the instructions and all will be good. Then drink ya heart away |
| Author: | stocker [ Mon Feb 28, 2011 8:13 am ] |
shakes wrote: Bucket wrote: I can probably come out and give you a hand if you need. Let me know when you plan on doing it, as I'm a bit stretched for cash, even fuel this week :s syphon out some fuel as payment when you get there That would work only i have a diesel work truck and the tank from the vit. is currently sitting on my work bench with no fuel in it |
| Author: | abclarke [ Mon Feb 28, 2011 8:44 am ] |
stocker wrote: Im based in Glenwood near blacktown *shudders*
Not to far from my joint in campbelltown, when were you looking at doing it? I wouldnt mind giving you a hand so i can get an idea for mine |
| Author: | stocker [ Tue Mar 01, 2011 3:44 am ] |
no worries mate, well like i said i only just ordered it so i assume in the next week it will arrive in my hot little hands, so probably in the next couple of weeks, i would like to repaint underneath mine before i do the BL. so probably late this month early next month |
| Author: | Fluffy [ Tue Mar 01, 2011 4:54 am ] |
there is a tech thread on here I'm pretty sure.. I did mine a few years ago bending the shifters and getting them spot on was the hardest part. and if you're considering adding a spring lift might pay to re locate the passenger side front brake hose down the inner gaurd about 2 inches. oh and fuel filler hose.. mine ended up cracking . I suspect due to being pulled to tight Keep in mind the body has male studs about 2 inches long.. you need to lift the body about 4 inches in order to slip in the 2 inch body lift blocks. Anything that runs between the body and chassis can be pulled tight and could damage it long crowbar might be usefull Fluff |
