It is currently Wed Nov 04, 2026 11:27 pm
Post Posted: Fri Mar 04, 2011 4:29 am
hey guys was just wondering what this could be caused from i haven't played with any wires or anything and i can not turn them off had to disconnect battery
Post Posted: Fri Mar 04, 2011 4:31 am
fuse box under the dash, top row, 3rd or 4th fuse from teh left
Post Posted: Fri Mar 04, 2011 4:36 am
okay so tried them two didn't go off so i pulled them all and still on but the 5th one from the left was a Little bit melted
Post Posted: Fri Mar 04, 2011 5:51 am
does anyone know what this could be?
Vehicle: 75 Cruiser
Post Posted: Fri Mar 04, 2011 6:00 am
How about flicking the higbeam lever backwards and forwards , like the contacts could be stuck on?
Post Posted: Fri Mar 04, 2011 6:01 am
fuse box under the dash, top row, 3rd or 4th fuse from teh left..
You need to replace it, not just pull it...
I want my old sig back :(
Post Posted: Fri Mar 04, 2011 6:04 am
tried it several time was thinking about just cutting the wire from the column or from the back of the headlight but wasn't too sure whether it could cause drainage problems. and ben I just figured since it had no fuse they wouldn't work but when this rain stops i will replace them both
Post Posted: Fri Mar 04, 2011 7:11 am
doesn't work like that, a blown fuse is technically not there, as there is a break circuit once the fuse is blown..
That & Mr Suzuki was on acid when he designed the sierra harness.. :stekky:
Post Posted: Fri Mar 04, 2011 7:19 am
okay so put new fuses in and still no luck still on and now i have a dead battery to go with it so any other suggestions i don't use high beam anyway so it doesn't bother me if i cant use it again.
Post Posted: Fri Mar 04, 2011 8:01 am
is the fuse still good?? or has it blown??
Post Posted: Fri Mar 04, 2011 8:08 am
they were still good but the 5th one had melted a little
Post Posted: Fri Mar 04, 2011 8:11 am
The new one's???
If the fuse is blown again, unplug all tail & parker light's, replace blown fuse & plug the light's back in one by one, checking the fuse each time, when you plug one in & it blow's the fuse you have found the circuit with the fault..
Post Posted: Fri Mar 04, 2011 8:26 am
here is another one for ya steekkyy
whenever it rains my wipers auto come on and stay on until the key is turned
off, even if the wipers aren't actually turned on.
Post Posted: Fri Mar 04, 2011 8:28 am
People pay to have option's like that... :lol:
do you get water on the passenger floor??
Post Posted: Fri Mar 04, 2011 8:30 am
not the new ones the new fuses i put in are fine so were the old ones it was only the 5th across that was melted i just replaced them to be sure.
Post Posted: Fri Mar 04, 2011 8:33 am
get water everywhere, even in the glove box :lol:
Post Posted: Fri Mar 04, 2011 8:36 am
8O But your glove's will get wet!!!! 8O
Post Posted: Fri Mar 04, 2011 8:38 am
narh i only keep spare (well leftover) bolts in there
Users browsing this forum: Google [Bot] and 179 guests
