It is currently Fri Nov 06, 2026 4:16 am
Vehicle: 98 Maruti
Post Posted: Mon Mar 07, 2011 10:56 am
hi all, my sierras current engine is getting very long in the tooth, and im looking to replaced it. i am looking to keep the 1.3
after no luck finding a suitable motor i scored a unknown condition motor for a carton of piss. i just removed the head and found a bit of water in the 2nd and 3rd cilinder (from being out in weather) so my question is this block to far gone? thanks
Post Posted: Mon Mar 07, 2011 11:10 am
What is the bore size ?
Post Posted: Mon Mar 07, 2011 11:26 am
Looks good to me, especially if it's standard bore.
Vehicle: 98 Maruti
Post Posted: Mon Mar 07, 2011 11:38 am
pretty sure its stock bore size
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Mon Mar 07, 2011 12:06 pm
you're a can of wd40 away from a shmick looking block!
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Post Posted: Mon Mar 07, 2011 5:56 pm
Clean it up - if necessary bore +0.02 OS.
Vehicle: 03 Jimny
Post Posted: Mon Mar 07, 2011 9:20 pm
Looks alright to me
If it's standard bore size, just clean the block up nd get it bored to 20 thou over and get new pistons to match
Vehicle: 98 Maruti
Post Posted: Tue Mar 08, 2011 3:04 am
i can see a little bit of pitting on one or two of the cylinders, would this mean it is best to clean it up (degrease it like crazy) myself then take it to someone that can give it a final proper clean and bore it out a little?
and should i be getting the head re skimmed?
also were is the best place to buy a rebuild kit for the g13?
this is (obviously) my first engine rebuild :D
Vehicle: 03 Jimny
Post Posted: Tue Mar 08, 2011 3:34 am
Clean it up as much as you can
Get it bored out to 20 thou
Get you head and block shaved
I got all my parts from t-Mac
Not sure what you have around your area
Vehicle: 98 Maruti
Post Posted: Tue Mar 08, 2011 6:45 am
for the rebuild kit i was looking at a master rebuld kit from lowrange
has being the best price iv seen so far
http://www.lowrangeoffroad.com/suzuki/s ... parts.html
Post Posted: Tue Mar 08, 2011 6:51 am
http://www.acl.com.au/
:helloo: buy aus made, I've been using ACL for yr's... :P
Vehicle: 03 Jimny
Post Posted: Tue Mar 08, 2011 8:14 am
i wouldnt buy standard size pistons either
Vehicle: LJ20 LJ50
Post Posted: Tue Mar 08, 2011 8:48 am
put it back to gether and slap it in. She will be right
Camels have nice toes
Users browsing this forum: Google [Bot] and 177 guests
