It is currently Fri Nov 06, 2026 4:15 am
Post Posted: Wed Mar 09, 2011 5:40 am
Hi fellas,
I bought the OME H/D springs & shock kit and fitted em, but obviously as the car is now the springs are way too stiff.
with the OME H/D, is the stiffness just added leafs or is it the strength in the individual leafs? there are 2 more leafs on there over stock.
Also is the shock more stiff too?
Thanks
Post Posted: Wed Mar 09, 2011 5:47 am
they will soften a little in time, the standard OME lifted (what I have) have 5 leaves in the pack (rear) and 4 in the front. So I would say its spring rate of the leaves used
My Rig --> Click WWW
Post Posted: Wed Mar 09, 2011 5:49 am
Only difference between OME HD's arn OME mediums is an extra leaf. Same individual leave thickness's
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Mar 09, 2011 5:54 am
o yeah I forgot rears had 4 at standard
Jr is righter than me
Post Posted: Wed Mar 09, 2011 6:22 am
Jr researched the bejebus out of spring's & ruf... :P
Post Posted: Wed Mar 09, 2011 9:42 am
thanks guys. how hard is it to remove a leaf from the bottom?
Post Posted: Wed Mar 09, 2011 9:43 am
Vehicle: 2018 DMAX
Post Posted: Wed Mar 09, 2011 9:53 am
This should cover it..
steak_knife wrote:
boostedbrick wrote:
Jack it up, and support the chassis on stands.
Remove wheels.
Undo bottom shock mount and remove shock from mount. 17mm
Undo the four nuts holding the U bolts on. 19mm
Remove u bolts and the plate.
There is a stud and nut running through the leaf pack. This needs to be undone, you may wish to hold the spring pack compressed on either end with vice grips(not the leaf you wish to remove).
Remove bottom leaf
Do the stud back up and reverse what you did before.
You may need to hold the top of the stud with multigrips, just lift the axel up off the top of the leaf pack and you can get to it..
I always soak my nuts in WD40 a few hours before hand...
I highly recommend doing this, use 2 g clamp's to hold the spring's together near where the perch sits, I have had spring's fly apart when not clamped...
Users browsing this forum: Google [Bot] and 187 guests
