https://auszookers.com/forum/
electrical problem, radio resets using indicators
https://auszookers.com/forum/viewtopic.php?f=5&t=19863
Author:  experament-u2 [ Wed Mar 09, 2011 11:17 am ]
Post subject:  electrical problem, radio resets using indicators
ok have an electrical problem
only happens after driving in rain/sitting in rain
-when driving(in rain or after rain/water involved) if i indicate the radio restarts. or sometimes if i turn the lights on teh radio restarts.
-then turning the car off for the night results in a dead battery in the morning :evil:
the car is a 92 sierra, had driving lights wired in (dont work, terminals are corroded on relay) and has the clicky starter fix wiring. its a non stock radio.
if anyone could point me in the right direction, i would be extreamly greatful as its driving me nuts
Author:  Ben_Sierra [ Wed Mar 09, 2011 12:41 pm ]
Post subject:  Re: electrical problem, radio resets using indicators
I'd say that when its wet the water is getting in somewhere and shorting something out... Check all your connections are nicely insulated (grab some electrical tape) and give all the connections a good spray with WD40 to help keep the water out and stop any corrosion.
Author:  charlie [ Wed Mar 09, 2011 9:33 pm ]
Check for a dead cell in the battery , my wifes standard corrlla reset it self everynow & then rain or not raining
Author:  squizzytaylor [ Wed Mar 09, 2011 10:19 pm ]
Sounds like an earth problem to me.
GT
Author:  inbits [ Thu Mar 10, 2011 12:43 am ]
GT
Check all your earth points and all your terminals that are corroded clean them up and as ben said give then a spray with wd-40 or inox
Author:  Scrawny [ Thu Mar 10, 2011 1:04 am ]
Move to Qld, noone bothers using indicators down here :roll:
Author:  experament-u2 [ Thu Mar 10, 2011 8:45 am ]
brandnew seal battery, bat terminals are new to, after jump starting it again today i noticed somthing
- after starting and driving through a car park everything was working, then went over a speed bump and felt water dripping on my feet, and the elect problems started again. so i am thinking it may have somthing to do with water getting under that dash.
- i also think teh alt is dead, i was getting 11.3 at teh battery with teh engien running
Author:  inbits [ Thu Mar 10, 2011 8:52 am ]
Sounds like it's holding water somewhere up there get a hose
And hose down and look for the leak
And the alt definitely sounds like it's dead
Author:  experament-u2 [ Thu Mar 10, 2011 8:55 am ]
it just rained before we jumped it so it makes sence the water leaking under teh windsheild is shorting somthing
Author:  inbits [ Thu Mar 10, 2011 9:00 am ]
Fair enough I'd be looking for the leak and any terminals under the dash that would be getting wet and aren't insulated and fixing them up
Author:  experament-u2 [ Thu Mar 10, 2011 9:05 am ]
thanks Inbits
i think thats my mission for the weekend, get teh windscreen down and seal then check dash and finally replace alt, may as well try do the ford alt while im at it.
