| G16B block into jimny? https://auszookers.com/forum/viewtopic.php?f=5&t=19919 |
| Author: | Gizmo3332 [ Fri Mar 11, 2011 6:45 pm ] |
| Post subject: | G16B block into jimny? |
Hey guys, I have been after a little more up and for the zuk, its running a stock g13bb I was wondering if a g16b bottem end will bolt up to the standard engine mounts? And willit fit to the g13bb gear box? Cheers Dale |
| Author: | steak_knife [ Fri Mar 11, 2011 6:55 pm ] |
| Post subject: | Re: G16B block into jimny? |
http://auszookers.com/index.php?name=Fo ... ic&t=15009 It'll fit.... |
| Author: | Gizmo3332 [ Fri Mar 11, 2011 10:08 pm ] |
Arent those adaptors for sierras? Or are they the same? Also will any wiring need to be changed to suit the bigger bottom end? |
| Author: | steak_knife [ Fri Mar 11, 2011 10:47 pm ] |
Yes, yes Doubt it.. |
| Author: | smiffkid [ Fri Mar 11, 2011 11:16 pm ] |
when we put a g16b out of a baleno in our jimny, we used the original computer, but because it was out of a front wheel drive we had to change a few things, pretty simple conversion, |
| Author: | inbits [ Fri Mar 11, 2011 11:29 pm ] |
Is it safe to use the Jimny ecu and head on a g16? similar to using h20a heads ecu and sensors on h25a Would it run lean? |
| Author: | smiffkid [ Fri Mar 11, 2011 11:46 pm ] |
i just used the complete g16, so im not sure |
| Author: | Gizmo3332 [ Sat Mar 12, 2011 4:02 am ] |
Ive heard they go harder than a normal 1.6 with a 1.6 block and 1.3 head |
| Author: | Gizmo3332 [ Tue Mar 15, 2011 4:50 am ] |
Also what needed to be changed with the fwd engine? Was the power increase noticeable? |
| Author: | Taylor74 [ Tue Mar 15, 2011 9:52 am ] |
Get the adapter kit from suzistore. There new kit allows the water pipe to go through the drivers side engine mount for a complete bolt up. You do need to play around with the AC bracket with the block being a bit taller. I use the standard G13bb ecu and harness but put the injectors from the type 3 (twin coil pack) baleno in. Seems to go almost as good as the complete change to baleno injection and you have the option of adjusting the timing later with the BB injection. You will need to change the sump and pick up and cam from the jimney to do this and oh yet there is a big difference |
| Author: | smiffkid [ Tue Mar 15, 2011 11:59 am ] |
ours was a noticeable difference with the g16 then the g13, it goes better now even with the 31s then what it did when it was completely stock, also running type 3 injectors |
| Author: | steak_knife [ Wed Mar 16, 2011 5:52 am ] |
Mr Taylor74, do you know if the bal throttle body will bolt on to a jim manifold & will the sensor's be in range for the jim Ecu?? |
