It is currently Thu Nov 05, 2026 3:05 am
Vehicle: White A/T Jimny
Post Posted: Mon Mar 14, 2011 5:33 am
ok so my engine is pretty badly damaged and i was quoted $3000 to rebuild it to "good as new". My head appears fine. I hav however seen reconditioned 1.6 litre blocks for sale (suzisport.com) for $1800 (conversion kit included) were u keep the same head. It would be a plus to hav a few more kw with the 1.6 so what does everyone rekon the conversion would set me back? also how would the procedure differ from a manual jimny?
Thanks
Post Posted: Mon Mar 14, 2011 5:41 am
Thanks
I'm interested to know who's quoting 3 grand for an engine rebuild. If your head is fine 3 grand is about 3 times what i'd expect to be paying.
Post Posted: Mon Mar 14, 2011 6:54 am
3k is reasonable if he is removing and fitting, most places will want to replace a heap of bolt ons and deck the head, new water pump, oil pump
ect... it all adds up
Post Posted: Mon Mar 14, 2011 7:17 am
fml thats not good, if i was too get the refurbished 1.6 with all the kit to install it for $1800, wat u rekon the install itself would cost?
Post Posted: Mon Mar 14, 2011 7:19 am
btw anyone a good place that wont rip me off to get a engine swap done around northside brisbane?
Post Posted: Mon Mar 14, 2011 7:21 am
in w.a. you get charged between $4500-$7500 for a 1.6 mpfi engine and conversion.
Post Posted: Mon Mar 14, 2011 7:52 am
Being a jimmy and having mpfi will make it easier. All the gear off your 1.3 should bolt on. You would need to get a a gasket kit and if you get the adapter kit with the new engine it should be a weekend
In the shed
That's provided it's safe to use the 1.3 injection and ecu on the 1.6
Post Posted: Mon Mar 14, 2011 10:34 am
In the shed
If my assumption that the G13BB engine has a MAF sensor my semi-educated guess is that the injection would be OK. Does anyone know the injector size that the G13BB has? I'd say the injectors would have enough headroom.
Post Posted: Mon Mar 14, 2011 10:50 am
Damo wrote:
In the shed
I know a couple of guys running Jimny heads on 1.6 bottom ends, AFAIK they have the standard injectors...
I want my old sig back :(
Post Posted: Mon Mar 14, 2011 9:11 pm
so anyone know wat the labour would cost for rebuilding my g13bb versus swapping to a g16b?
Post Posted: Mon Mar 14, 2011 9:15 pm
It would be a fairly simple job. You will need an adaptor plate also for the 1.6 to 1.3 gearbox from BenT on here or lowrange or similar
Post Posted: Tue Mar 15, 2011 4:41 am
We have one car in the club here in Vic currently running Jimny injections on a 1.6 bottom end. It seems to run pretty good. It hasn't been on a dyno or been run with a wideband 02 sensor to prove it's not doing anything odd, but seat of the pants says it's not far off.
This car runs an AW-4 auto from a vitara though, and I think that's important.
I'm not sure I'd run a Jimny auto behind a 1.6. The Jimny auto is right at the limit of it's torque handling capability with a G13BB. It is, in fact, a special "low torque"design Aisin-Warner made for the 660cc Jmny and it's been adapted to the 1.3.
General consensus us they are marginal with the 1.3.
There are no upgrade parts, the auto wasn't used in any other models, they don't last especially well even with a 1.3, they are near impossible to find at wreckers (as a result), and suzuki want $8.5K for a replacement. (Yes, really. $8500)
We have a car running a Jimny auto with a G13BB in the club. I don't recall the KM's on the engine when the owner bought it. to date, it's been fine, however, the car isn't daily driven, it runs an enormous auto trans cooler and a temp gauge. The owner also runs lots of gearing, 35's, and off roads the car hard, but it would be unlikely it travels more than 5000km a year.
Just some thoughts.
It would be a shame to spend $1800+adapter plate and other fiddling around and then lunch the auto.
Post Posted: Tue Mar 15, 2011 5:01 am
PM woody re pricing, he had a full reco done on his g13bb a bout a year ago I think.
Users browsing this forum: Google [Bot] and 264 guests
