It is currently Thu Nov 05, 2026 2:12 pm
Post Posted: Wed Mar 16, 2011 11:17 pm
Hi, I have just pulled the transfer case from my Suzuki SJ40 apart and the gear teeth inside the selector gear are VERY warn and the bearings and seals are shot so I am thinking of replacing it with a second-hand box.
Is there any advantages or draw backs in using a 1.3lt. case (I am also putting a 1.3lt engine and gearbox in it.
Tony
Vehicle: 2018 DMAX
Post Posted: Wed Mar 16, 2011 11:28 pm
Alot of 1.3 blokes are trying to fit 1liter cases for better gearing... Depends on what you want todo with it gearing wise i guess?
Post Posted: Thu Mar 17, 2011 12:25 am
1.0 transfer is 12% lower in high and low than a 1.3 case.
If you are fitting a 1.3 motor/box and keeping your 4.11 (1.0) diffs then a 1.3 transfer will be fine as your diffs will pull your overall ratio down to below a stock 1.3. Should run 235/75-15's beautifully.
Post Posted: Thu Mar 17, 2011 12:38 am
Thank you Want33s - Are the mountings about the same or is there big mods to do?
Tony
Post Posted: Thu Mar 17, 2011 2:22 am
A 1.3 case should bolt straight in as long as you get the brackets with it...
You might find the holes in the chassis mounts are big but large thick washers will sort that out.
Post Posted: Thu Mar 17, 2011 4:45 am
Thanks mate
Users browsing this forum: No registered users and 18 guests
