It is currently Fri Nov 06, 2026 3:27 am
Post Posted: Tue Mar 15, 2011 11:36 am
hi guys, went for a drive with some mates tonite, did a bit of creek crossing stuff... just wondering how you guys are sealing your handbrakes from letting any water into the cabin? mine pisses through like theres no tomorow... unless i'm missing a rubber of some sort maybe?
Post Posted: Tue Mar 15, 2011 11:46 am
Thats the least of my worries, normally its coming through the doors and softtop...
I just remove the floor bungs and let the water out once I've gone through ;)
I want my old sig back :(
Post Posted: Tue Mar 15, 2011 12:01 pm
i have my floor plugs out in winter so i sink... if i leave them in the water doesnt come in fast enough and i float off the line i was on and lose momentum... lol
Post Posted: Tue Mar 15, 2011 6:51 pm
yerp thats a good idea alien
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Tue Mar 15, 2011 8:36 pm
There is a plate that bolts to the floor, this is what your lever is hinged on. Between that plate and the body should be a rubber seal, if that's missing it will most likely let in water like you describe.
Post Posted: Tue Mar 15, 2011 8:54 pm
what decade was that? it hasnt rained in WA for about 12 years has it? :lol:
Post Posted: Tue Mar 15, 2011 9:41 pm
you're not far off =P
Post Posted: Wed Mar 16, 2011 5:18 am
true... so looks like i'm missing the rubber seal then.. as when i'm under the car i can see daylight through the handbrake lever mechanism quite easily...thanks for clearing that up :)
Post Posted: Wed Mar 16, 2011 6:19 am
Close to the reason mine are out, took em out cause it rained, forgot where I put em... :roll:
Users browsing this forum: No registered users and 85 guests
