Hi, I have just pulled the transfer case from my Suzuki SJ40 apart and the gear teeth inside the selector gear are VERY warn and the bearings and seals are shot so I am thinking of replacing it with a second-hand box.
Is there any advantages or draw backs in using a 1.3lt. case (I am also putting a 1.3lt engine and gearbox in it.
1.0 transfer is 12% lower in high and low than a 1.3 case.
If you are fitting a 1.3 motor/box and keeping your 4.11 (1.0) diffs then a 1.3 transfer will be fine as your diffs will pull your overall ratio down to below a stock 1.3. Should run 235/75-15's beautifully.
A 1.3 case should bolt straight in as long as you get the brackets with it...
You might find the holes in the chassis mounts are big but large thick washers will sort that out.
Users browsing this forum: No registered users and 25 guests
