It is currently Thu Nov 05, 2026 9:09 am
Vehicle: 4wd
Post Posted: Thu Mar 24, 2011 6:35 am
Hello,
This morning I thought I'd test out the Sierra heating.
In doing so I noticed that the fan only works on high speed.
Low and Medium do nothing. What causes this? And how do I fix it?
Watch out or you'll get sued.
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Thu Mar 24, 2011 6:40 am
sounds like the resistor coil inside the heater box has failed.... find anotehr one would be my guess
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Vehicle: 4wd
Post Posted: Thu Mar 24, 2011 7:06 am
When you say heater box you mean the fan box or the box the controls are in?
Vehicle: 4wd
Post Posted: Fri Mar 25, 2011 12:02 am
Anyone else able to help?
Post Posted: Fri Mar 25, 2011 12:03 am
My fan switch carked it in Suz. The wires rattled loose. All i did was re- solder them. Good as new.
Post Posted: Fri Mar 25, 2011 12:04 am
on the side of the heater there is a little metal plate held in by 2 screws and has some wires plugged into it, unscrew it and pull it out for a look, you might find the bimetallic strip is dirty
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 60 guests
