It is currently Thu Nov 05, 2026 4:08 am
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Mar 25, 2011 10:33 am
I chucked a small tub of stop leak into the radiator to stop a slow leak through the thermostat gasket. Oily stuff and a heap of pellets.
Coolant now looks like shit after 24 hrs - frothy and oily, but the leak has stopped. Am I supposed to replace the coolant after using the stop leak, or do you just leave it as is?
Post Posted: Fri Mar 25, 2011 10:35 am
Leave it.
Why use that stuff when you could just replace a $1 gasket??
Post Posted: Fri Mar 25, 2011 10:44 am
Or even better just use some pepper out of the kitchen cupboard :D
Vehicle: 03 Jimny
Post Posted: Fri Mar 25, 2011 10:47 am
Or a egg
Post Posted: Fri Mar 25, 2011 11:36 am
I replaced the thermostat months ago - gasket was an easy job and razor bladed both surfaces clean. Random leak popped up about a month after the fix.
Just giving it a try - like you say a gasket is an easy enough fix, but you lose a heap of coolant getting the hose off. Got no spare gaskets or jiuce lying around so giving it a try to see if actually works
Post Posted: Fri Mar 25, 2011 12:12 pm
I wonder how that stuff reacts with the metal from the motor?
helloo
Post Posted: Fri Mar 25, 2011 12:18 pm
im pretty sure it leaves a fine film inside all the hoses and the engine and takes AGES to get rid of (lots of flushing out).
i dunno dude - given you're about to embark on a huge journey i'd have tried a new gasket first.
Post Posted: Sat Mar 26, 2011 1:14 am
Ha ha, how did I get two posts happening? Forum in stereo
Vehicle: LWB Sierra & XL7
Post Posted: Sat Mar 26, 2011 1:48 am
I put a bit of gasket silicon on both sides of the gasket, Sure it's a bit overkill, but that's how it was when I removed it and I know for sure it won't leak.
'92 Vitara & Camper trailer
Users browsing this forum: Google [Bot] and 410 guests
