| cheap short wheel base vitara rear axle upgrade. https://auszookers.com/forum/viewtopic.php?f=5&t=20371 |
| Author: | Timbo_ [ Sat Mar 26, 2011 7:01 am ] |
| Post subject: | cheap short wheel base vitara rear axle upgrade. |
I have used alot of usefull info from here. So thought id put some back. Here is a cheap alternative to chromo rear axles for vitara's, for those breaking them on the tracks. Here we go. The left is from a short wheel base, the right is for the long wheel base. The long wheel base is a heck of alot thicker, being stronger.
| Author: | Timbo_ [ Sat Mar 26, 2011 7:05 am ] |
| Post subject: | Re: cheap short wheel base vitara rear axle upgrade. |
they run same bearings as the SWB with no modification to the housing. and cheap as chips compared to chromoly. |
| Author: | shandy92 [ Sat Mar 26, 2011 7:33 am ] |
how much stronger would they be tho? and how much are the lwb axles worth? |
| Author: | Timbo_ [ Sat Mar 26, 2011 7:45 am ] |
not sure mate, havent snapped my axles and had to put them in yet. But they are alot thicker. As for how much they are worth? Up here, no one wants them, so next to nothing, i got mine for free. |
| Author: | ajsr [ Sat Mar 26, 2011 7:46 am ] |
they both neck down to the same size by the looks so thats where they will go |
| Author: | Timbo_ [ Sat Mar 26, 2011 7:53 am ] |
this is true, and thats where most of them do go anyway. |
| Author: | christover1 [ Sat Mar 26, 2011 8:39 am ] |
This means I could carry a SWB axle as a SPARE for my LWB, thanks I was wondering if they were different. Would like a set from LOWRANGE, but at $400 a set, won't happen unless I break lots, and w2in tatts. Will get some spares, easy to change. |
| Author: | christover1 [ Sat Mar 26, 2011 8:43 am ] |
http://www.lowrangeoffroad.com/suzuki/s ... hafts.html low range hd axles look very much similar to lwb design, probably better steel maybe |
| Author: | remydog05 [ Sat Mar 26, 2011 9:19 am ] |
Chris there is a Vitara at Center Road Wreakers and I took the Center and housing out of it today and left the axels in the car. They only charge $34 per axel if you need one for spare. |
| Author: | christover1 [ Sat Mar 26, 2011 9:35 am ] |
remydog05 wrote: Chris there is a Vitara at Center Road Wreakers and I took the Center and housing out of it today and left the axels in the car.
They only charge $34 per axel if you need one for spare. Very cool, thanks, good to know. Will probably start collecting a few spares, once modding stage is over |
| Author: | christover1 [ Sat Mar 26, 2011 9:36 am ] |
If Modding stage ever actually ends lol |
