It is currently Fri Nov 06, 2026 8:56 am
Post Posted: Sat Apr 02, 2011 4:34 pm
hey guys,
I will be doing a disc brake conversion on my LJ next week. At the same time i'll be rebuilding the swivel hubs, replacing wheel bearings, kingpins and packing the cv's.
Just wondering what is the best grease for each of the bearings, the cv's and the swivel housing?
I bought a tub of castrol htb but someone was telling me to use lithium based grease because of it's resistance to water? :?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Sat Apr 02, 2011 5:38 pm
I used bearing grease on all bearings an c.v. grease in c.v.. :helloo:
Post Posted: Sat Apr 02, 2011 8:25 pm
bearing's you want HTB grease (High Temp Bearing)
For the Cv's & hub a molly, I have run HTB in hub's, worked well but I believe the short cv life could of been because I was to cheap to get different grease when I had HTB in stock..
:helloo: get lot's of rag's to, ripco sell 20kg bag's of the bugger's...
Post Posted: Sat Apr 02, 2011 9:01 pm
Yes, you need lots of rags. An idea might be to put a drain pan under the swivel housing cos of all the yukky stuff that comes out :wink:
I use HTB grease for everything 8O
Post Posted: Sat Apr 02, 2011 9:13 pm
It does work, "BUT" , cv's need some different property's, they don't get any where near as hot..
Post Posted: Sat Apr 02, 2011 10:30 pm
bursons down here keep a moreys product called bigfoot its a universal ht bearing/cv joint with waterproof servere shear properties, supposed mine spec grease
all of the farmers out my way are using it as it apparently wont wash off even with a good hand cleaner. its floro orange in color
Ive got a box on order as we speak as im sick of having different greases.
linky http://www.moreyoil.co.nz/details.php?& ... roductID=8
Post Posted: Sat Apr 02, 2011 11:00 pm
hooki wrote:
hey guys,
Yes, lithium waterproofs grease.
Post Posted: Sat Apr 02, 2011 11:57 pm
Does it wash out with oil tho?
Post Posted: Sun Apr 03, 2011 12:03 am
I suppose like most greases yes oil would dilute it.
But this stuff is the stickiest shit ive ever seen, I'm using it so I can use the same guns to do wheel bearings on my trailers and piviot pins and slides on cherry pickers etc.
we get very wet winters etc where I live and good water washout greases are a must if you want shit to last.
Post Posted: Sun Apr 03, 2011 12:09 am
That looks like good stuff, very good.
Post Posted: Sun Apr 03, 2011 1:01 am
Go with the 180kg Drum ;) i'll buy a kg :P
Stocker
Users browsing this forum: No registered users and 165 guests
