It is currently Mon Oct 19, 2026 4:04 am
Post Posted: Tue May 06, 2008 2:10 pm
I saw Steve's new tyres yesterday :mrgreen: and it got me thinking about mine again :roll: but the 235/85 size I like needs 16" rims, of which there aren't a lot of choices when it comes to the zook stud pattern. I think GV's had 16 x 7s but they dont come up that often, and price wise you might as well buy new sunraysias (which only come in 16x with 0 offset AFAIK).
Anyone got any other bright ideas?
Vehicle: 75 Cruiser
Post Posted: Tue May 06, 2008 2:17 pm
change it to 6 stud pattern?
Post Posted: Tue May 06, 2008 2:38 pm
I had thought about that. Might have to get fluffy to make me up some new front hubs?
Post Posted: Tue May 06, 2008 2:55 pm
I remember a guy had some strange rims that were 16x7 that looked like split rims but werent, said they came off a Jep or F100, cant remember
get some 16x7 bands and weld your own centres in?
Vehicle: 75 Cruiser
Post Posted: Tue May 06, 2008 2:57 pm
1. change stud pattern on current diffs
2. cut a few rims up and reweld 5 stud centers in to new 16 inch rims
3. get hilux or similiar 6 stud diffs
4. don't get 16 inch rims because it's too much trouble
Post Posted: Tue May 06, 2008 4:36 pm
custom sunnys???
they should be able to give you some pretty decent offset.
Web wheeler extroadinaire
Post Posted: Thu May 08, 2008 1:09 am
I would need some 16" rims to cut the centres out of, so that sort of wouldn't work! :lol:
I could get custom wheels, or order 16" sunny's but that's the exact reason I want to get away from the zook stud pattern, that there just isn't a lot of wheels around in that pattern.
I think the best way to go is change to 6 stud pattern. Sounds easy enough but there is a little problem. Sure the rears isn't a big drama, that can be welded up and re-drilled. The fronts however are a different story. The flange that the studs are pressed into isn't a full circle, it's just 5 'tabs', which is going to make it pretty hard to mount 6 wheel studs into.
So short of having a set of hubs machined up I don't think there is any other way of doing it. Well, you could make up a set of wheel spacers that have 5 holes and 6 studs, but that wouldnt really end up being any cheaper than a pair of hubs, and I think the hubs would be a better way to go. Unless of course you could get a hilux (or other 6 stud) hub to fit, but I doubt that there will be one that will.
Post Posted: Thu May 08, 2008 1:17 am
find some suzuki 6 stud hubs :)
or bling alloy wheels :)
Post Posted: Thu May 08, 2008 1:22 am
If I can find some of those then yeah no worries! They are kinda elusive though.
It will be mush easier to do once I can go 6 stud :wink: I hope Royce still talks to me when I have TOYOTA rims :P
Post Posted: Thu May 08, 2008 1:25 am
what model of car has the same PCD as suzuki and a large market for alloy wheels in various sizes and shapes :wink:
Post Posted: Thu May 08, 2008 1:40 am
Vit? Pity about the poxy offset. F truck? Ok if you're in the US, still relatively rare over here compared to 6 stud.
Kia, Diahatsu, old Jeeps? Nup.
Got me stuffed!?
Post Posted: Thu May 08, 2008 1:41 am
current wranglers are same arent they? or is my next line about every 2nd one around here being blinged to the hilt going to be shot down in flames
Post Posted: Thu May 08, 2008 1:43 am
NFI. The old ones were 5 x 4.5" PCD. Anyway, I doubt the new ones have hubs, so the centre hole wont be big enough to fit over the locking hub.
Post Posted: Thu May 08, 2008 1:49 am
all them cheap wheels the chickies round here buy still have big holes
I could tell you about the 16" rims I saw with 15" centres in them but I dont think you would apprecieate the fine engineering that went into filling the gap :oops:
Users browsing this forum: No registered users and 308 guests
