https://auszookers.com/forum/
spring over axle help!
https://auszookers.com/forum/viewtopic.php?f=5&t=20705
Author:  jmd-247 [ Tue Apr 05, 2011 8:51 am ]
Post subject:  spring over axle help!
Couldnt find a specific enough topic on her, got some info, but not enough.
I want to do a spring over axle conversion on my sierra 94 model.
ATM it is stock as a rock.
When placing the leaves ontop of the axle does the small flat plates welded to the axle on the bottom have o be duplicated to the top??
i dont think i will need new shockies as the mount is reversed to the top.
will i need longer brake lines?
and will steering system be long enough?
Any answers will help.'
I have done other cars but not the zook! any help greatly appreciated!~
Author:  Jackson [ Tue Apr 05, 2011 9:01 am ]
Post subject:  Re: spring over axle help!
Hey,
I don't know the answer but what does spring over axle do?
Sorry to kinda highjack your thread.
Jackson
Author:  shakes [ Tue Apr 05, 2011 9:06 am ]
Jackson wrote:
Hey,
Jackson
Exactly that. puts the spring over the axle from underneath it, giving more lift a smidge more travel for a whole lot of work.
There is alot of haters here that will probably say if you have to ask these questions then you probably shouldn't be doing it....
brake lines and steering is best to see exacty how long and how far is needed when the axle is bolted back to the car and the suspension has been cycled. ;)
Author:  SierraDan [ Tue Apr 05, 2011 9:06 am ]
Jackson wrote:
Hey,
Jackson
A standard Sierra has the springs fixed underneath the diff.
A spring over means fixing the springs on top of the diff with lots of fabricating and expenses.
Author:  Jackson [ Tue Apr 05, 2011 9:09 am ]
Oh yeah I got the whole spring over the axle thing I just didn't know what you got out of doing it. Thanks
Author:  mnemonix [ Tue Apr 05, 2011 9:15 am ]
All your questions have answers that you won't like. Epic research fail.
Keep reading - you're not ready for SPOA if you're asking questions like this.
Author:  lump_a_charcoal [ Tue Apr 05, 2011 9:18 am ]
Plus it is illegal in most states, so do some research.
Author:  joeblow [ Tue Apr 05, 2011 9:18 am ]
If you think its fine to run the shocks you have in there at the moment........then.........
the spoa has failed allready. :?
Author:  joeblow [ Tue Apr 05, 2011 9:19 am ]
lump_a_charcoal wrote:
Plus it is legal in most states, so do some research.
fixed.
Author:  lump_a_charcoal [ Tue Apr 05, 2011 9:21 am ]
Sorry, my bad - thought the majority of states were anti SPOA.
Author:  alien [ Tue Apr 05, 2011 9:22 am ]
dude, you're 4 days late for april fools =)
infact there was only a topic on SPOA last week which had a fair bit of info in it (mostly people saying dont bother)... http://www.auszookers.com/index.php?nam ... ic&t=20502
Author:  alien [ Tue Apr 05, 2011 9:23 am ]
you can do anything with an engineers certificate... its illegal to modify the car without one anyway - technically a 2" lift and 215/75r15 tyres on a sierra are illegal in WA and need to be engineered.
Author:  alien [ Tue Apr 05, 2011 9:39 am ]
from: http://www.auszookers.com/index.php?nam ... hlight=215
alien wrote:
in WA its no more than 50mm lift INCLUDING tyre lift.
From the NCOP that WA follow: www.infrastructure.gov...eb2006.pdf from: www.infrastructure.gov..._ncop.aspx (page 20/71, section 4.10)
Modifications that result in raising the vehicle body greater than 50mm are to be carried out and approved in accordance with Codes LS7 and Code LS8.
LS7 - page 61 - point 1: Design of modifications that result in the vehicle body being raised by more than 50mm from the original "as manufactured" height.
Page 63: Wheels & Tyres - The overall tyre diameter can be increased by up to 26mm (four wheel drive vehicles only). Tyres fitted to commercial vehicles must not be more than 50% wider that the vehicle manufacturer's widest optional tyre.
The wheel track of off-road and four wheel drive vehicles must not be increased by more than 25mm...
LS8 - page 68 - point 1: Design of modifications that result in the vehicle body being raised by more than 50mm from the original "as manufactured" height. which includes points 6. installation of body lift and 7. alternative wheel and tyre specifications with modified axles or suspension.
So in essence.. a 215/75r15 is in fact ILLEGAL to run on a vehicle that has a stock 205/70r15 as its 35.5mm larger - exceeding the maximum allowed increase by 9.5mm, and running a larger tyre in combination with a lift of 50mm or more is also illegal.
Cool huh? =)
Author:  TryHard [ Tue Apr 05, 2011 10:24 am ]
Hey Alien was it Exp to get it Engineered still temped haha :D
Author:  alien [ Tue Apr 05, 2011 10:36 am ]
about $1500, so nope.
