It is currently Thu Nov 05, 2026 7:41 pm
Post Posted: Tue Apr 05, 2011 8:52 am
hey guys just wondering how to get those 2 studs out of the gearbox... u know the ones that you replace with the countersunk screws.
looking forward to replies im stuck lol
Post Posted: Tue Apr 05, 2011 8:57 am
also is that bracket that goes from the intake to the block nessesary... i had to remove it to fit the 1.3 engine mount (im using a baleno g16b)
Vehicle: G16b 83
Post Posted: Tue Apr 05, 2011 9:13 am
I just used multigrips to get mine out not sure bout that bracket I took mine off too
Post Posted: Tue Apr 05, 2011 10:28 am
put 2 nuts on the thread and lock them together by twisting them in opposite directions. this will allow you to remove or alternatively get a stud remover from repco
Post Posted: Tue Apr 05, 2011 11:25 am
unless you want a busted intake I'd be keeping it of making another less intrusive one..
Post Posted: Tue Apr 05, 2011 11:59 am
X2. The manifold will crack without the brace. Seen it happen many times. Happens to GTI motors too.
Post Posted: Tue Apr 05, 2011 12:11 pm
ok cheers guys. il have a look for a stud remover. ive already tried using multis but no success. and il have a go at making something up to support the intake
Post Posted: Tue Apr 05, 2011 12:16 pm
Wind a nut onto the stud. Then wind a second nut on and tighten against the first nut. Try to line the edges of the nuts up so that a socket can slide over both nuts. Then use a breaker bar to undo. Might work, but the two nuts will have to be VERY tight against one and another.
Post Posted: Tue Apr 05, 2011 12:30 pm
il give that a go tomoz before i go out and buy that tool. i im not worried if it doesnt work. more tools in the shed is always a good idea :)
Post Posted: Wed Apr 06, 2011 12:19 pm
nup no luck using the nuts to try and get the studs out. i ended up stipping the threads out of the nuts :0
might try making some flat spots on the stud with an angle grinder. then use a shifter to get them out.
Post Posted: Wed Apr 06, 2011 12:25 pm
barppp, will more than likely either round off again or snap the stud.. Neither are good outcomes.
If you going to shep it up. at least use a pair of vice grips, or even better some footprints. some rost off ice sprayed on the stud or similar will help too.
Post Posted: Wed Apr 06, 2011 12:28 pm
Weld the nut on
Post Posted: Wed Apr 06, 2011 12:34 pm
i would weld a nut on but ive got no welding gear. gonna go buy some vice grips tomorrow give that a shot. i have a blow torch would it be safe to heat it up then give it a try?
Post Posted: Wed Apr 06, 2011 7:57 pm
use a punch and smack it a few times with the hammer and use inox/wd40 and try to drive the thread in a tiny bit then undo it.
one option - grind the thread down to a flat on each side.. only a tiny bit!!!
and a good pair of vise grips with clean sharp jaws - ive seen a LOT that have been rounded and they make the job worse... -
While applying pressure to undo... smack the end with a hammer... it should dislodge any crud.
Heat gun will work as well... apply the heat around the stud hole... not the stud... - it'll melt the loctite thats in there which should make it easier to get out.
Vehicle: 4wd
Post Posted: Wed Apr 06, 2011 10:57 pm
I tried the old two nut trick too, and with minimum effort stripped the threads.
Welding a small breaker bar onto it made it very easy.
Watch out or you'll get sued.
Post Posted: Thu Apr 07, 2011 5:21 am
ok so ive tried everything except for welding now and no success. this is so annoying. got a mate coming around on the weekend to weld something to the studs the same way as stockman did
Ps stockman check ur build thread. got a question for ya
Users browsing this forum: No registered users and 182 guests
