| im getting pissed off https://auszookers.com/forum/viewtopic.php?f=5&t=20722 |
| Author: | redrocketsj50 [ Tue Apr 05, 2011 12:34 pm ] |
| Post subject: | im getting pissed off |
i have read this and all the others before anyone says anything.... http://www.auszookers.com/index.php?nam ... pic&t=4140 my problem is my petrol guage wont work i have a spare fuel sender unit i put in that works perfect but still doesnt read right.... so whats wrong does anyone know???? |
| Author: | fordem [ Tue Apr 05, 2011 1:06 pm ] |
| Post subject: | Re: im getting pissed off |
The probability is you have a bad connection somewhere - the tank not properly grounded, a corroded connection between the gauge and the sender - that sort of stuff. Disconnect the wire from the tank sender and ground it - do you get a full tank indication now? If not - check the wiring. |
| Author: | S13RR4 [ Tue Apr 05, 2011 8:28 pm ] |
mine never went to full properly so I couldn't trust it, So I started to measure how many km's I could get from a tank. That is my fuel gauge now. |
| Author: | zebra [ Tue Apr 05, 2011 10:08 pm ] |
if the wire is earthed out and it shows full on the dash you most likely have some obstuction in the tank or bad eath |
| Author: | redrocketsj50 [ Wed Apr 06, 2011 11:56 am ] |
thanks guys ill try earth it |
| Author: | Teracis [ Wed Apr 06, 2011 12:02 pm ] |
I had the same problem and it was the earth, all I did was run a bit of wire from a bolt on the chassis and put it under one of the bolts that holds the sender in the tank. Fixed straight away. Oh and that's the second thing I tried, first was testing it while the tank was out but that was only because the tank was out! |
