It is currently Thu Nov 05, 2026 2:11 pm
Vehicle: 96 LWB Vit
Post Posted: Thu Apr 07, 2011 1:00 am
Hi All,
Well I've succesfully blown up my alloy front diff, already have the steel GV diff in the garage, and will be rebuilding this with 5.12's once all the parts are ready. (Saving for the Air Locker :D - this is the main hold-up)
I'm planning on using the nylon bush from Bruce or ODA1 with a cut down LH axle, running a 'hopefully' standard LH side CV/Axle on the drivers side.
I've pulled both diffs down and found that mostly the bearings all look fine. Does anyone have an opinion as to whether it's OK to use the old bearings in the rebuild?
I've had no issues with bearing noise in the old alloy diff, but that may be different now that it's blown to pieces.
the GV diff looks to be 'mint' i doubt whether it's even been off-road.
Cheers for the input.
Buddies
I can't leave well enough alone....
Post Posted: Thu Apr 07, 2011 1:03 am
http://www.lowrangeoffroad.com/index.ph ... -kits.html
At US$109 for peace of mind, its gotta be worth it, doesn't it?
I want my old sig back :(
Post Posted: Thu Apr 07, 2011 1:17 am
Dont have a shower and put your dirty old cloths back on.
Change the bearings while they are accessible, sheer folly to use the old ones.
Post Posted: Thu Apr 07, 2011 2:04 am
I'm a tight ar...wad, cos I have to be.
Even tho I re-use a lot of old parts in builds,
I would never use bearings from an exploded diff.
It could have nasty bits of metal inside the bearings.
if using old bearings, dont get them\bits mixed up.
As wear patterns can eat them up faster.
Once removed a bearing is often damaged,
and new ones are not too dear.
Hope all goes well.
Users browsing this forum: No registered users and 25 guests
