It is currently Mon Oct 19, 2026 5:08 am
Post Posted: Sun May 11, 2008 6:12 pm
hey ..on my 91 vitara carby ..of a morning when its cold it idles at about 2000rpm...which know there is something going on because it never used to do this... i know for sure it isnt the thermistat staying open to keep the engine cold because i replaced it a couple of days ago when i blew a hose....i remember a while ago reading about this sort of thing but i cant find the thread...something about a iac valve??...i found some topics like that but no help...i have searched the forums as well.. maybe someone could show me some pics of what i need to adjusted/fix etc or explain where it is.....thanks heap...mitch
Post Posted: Sun May 11, 2008 6:37 pm
YEah my little stocka (carby model) does the same thing untill the engine reaches temp, cold start idle 2,000rpm (about 5mins) then it goes back down to 1,000rpm.. I assumed this is normal for a cold start?
My other Vit Zilla (EFI model) on a cold start idles at 1,500rpm untill engine reaches temp (about 5mins) then goes back down to about 900rpm...
There was another thread on this a few monthes ago but I think in that case the idle wasn't ever coming back down to normal or the auto choke was jammed on.. :wink:
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Sun May 11, 2008 7:27 pm
yer a while ago it cold idled around 1500 and now its up to 2000 and stays on for ages......im goin through tanks pretty quick as well
Post Posted: Sun May 11, 2008 8:30 pm
did you put a colder thermostat in?
Post Posted: Sun May 11, 2008 11:29 pm
I don't even have cold idle :lol:
royce wouldn't a colder thermostat mean cold idle would shut off quicker or am i barking up the wrong tree :?
Vitara gone, tis no more. replaced by a 98 XH Falc
Post Posted: Sun May 11, 2008 11:35 pm
cold idle is controlled by a wax pellet thingo on the side of the carby, colder the water the more the thing pushes the lever that ups the idle
I dont think a cooler thermostat would make a difference unless there was something funny happening but doesnt hurt to ask, could also be a blockage or air bubble up there
Post Posted: Mon May 12, 2008 9:47 pm
i have no idea if its a colder one i when up to the car parts supplier and ask for a themostat to suit this car and they look the exact same.....so wats this about a wax pellet?
Post Posted: Mon May 12, 2008 9:51 pm
does the temp gauge sit in the same spot?
look on the side of the carby where the 2 water hoses go in its inside the cylinder they attach to
check both those hoses are getting hot too
Users browsing this forum: No registered users and 233 guests
