It is currently Fri Nov 06, 2026 6:02 pm
Vehicle: Jimny
Post Posted: Tue Apr 26, 2011 9:19 am
will a narrow track or a coily dash bolt into a sj50
Post Posted: Tue Apr 26, 2011 11:08 pm
WT will fit into a NT and vice versa, need to change the main bar across the vehicle aswell as the bracket that holds the heater control is different and gets in the way. SJ80 will not fit in either mdl as the fire wall is completly different on how the dash attaches.
you can use either NT or WT wireing harness for either dash, Just need to back ternimal out for taco and swap pin around on drivers side plug to make it work
Suzuki is my way of life.
Post Posted: Thu Apr 28, 2011 2:19 am
an SJ80 dash does fit, very well infact,not a bolt in tho but very easily fitted, just need the sj80 center bar and 3 new mount points on the fire wall at the top, piss easy, took me about an hr to fabricate and mount the new mounting points for the dash, well worth it if you can get your hands on one
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Thu Apr 28, 2011 2:23 am
I forgot about the SJ80 fan deck aswell, I can't remember much about everything else I done it years ago, if u can get your hands on a wrecked sj80 and all the components it's not hard, like I said well worth it Looks the part
Vehicle: Jimny
Post Posted: Thu Apr 28, 2011 6:42 am
Yeah they look schmick way better then my cracked one
DONT BUY A GQ! zooks are better. i have both :)
Users browsing this forum: Google [Bot] and 68 guests
