It is currently Sat Nov 07, 2026 11:56 am
Post new topic Reply to topic  [ 29 posts ]
Post Posted: Wed Apr 20, 2011 1:26 am
im pretty sure it just started. my 3 guesses are diff is on its way. uni joints are rooted or transfer is rooted.
anyone else have a good idea??
Post Posted: Wed Apr 20, 2011 1:37 am
Need more info, just clik/thud is pretty broad. As its only in first, I would at first guess, say its not any of the 3 you mention, as they will do it in any gear, most recognizable in first, but none the less, all gears.
Can you describe what it is better ? as in, as you lift your foot off the clutch, as you power on, as you coast ?? also the noise, pretend that Im deaf and need to go by feel; an explain that way.
Post Posted: Wed Apr 20, 2011 1:38 am
check all your unis are good and greased, grease the tailshaft splines, usually cures it unless a diff or something is shot
Post Posted: Wed Apr 20, 2011 1:43 am
as i lift my foot off the clutch its like there is play between something and has to catch up to engage.
i will check the uni's now.
thanks heaps guys
Post Posted: Wed Apr 20, 2011 8:25 am
grab the rear drive shaft and rotate it left to right. see if you can find out where the noise is coming from, or which side of the driveline the "clunk' originates from.
Vehicle: Daisy
Post Posted: Wed Apr 20, 2011 8:43 pm
You on holidays?
I'm not at work till next wednesday and just diagnosed the same problem in my zook, can help you find it if you want?
U have my number.
Post Posted: Thu Apr 21, 2011 4:57 am
tis the diff bearings on its way as diagnosed by one stop suzi shop.
time to start saving haha
Vehicle: Daisy
Post Posted: Thu Apr 21, 2011 5:24 am
I meant to ask if you know what it takes to replace these? Surely it's a get the bearings from weaves and rebuild it in the shed type of job?
Post Posted: Thu Apr 21, 2011 6:28 am
Don't save up - just fix it - The same happened to me a few years back and I kept driving thinking I would fix it when I got home and the bearing collapsed - Pinion shaft got bent and teeth came of the crown wheel - IE New diff.
Post Posted: Fri Apr 22, 2011 8:24 am
yeah thats it tim. bit of a prick from what i have herd.
hey tony. going to have to save up even to fix it myself. being a student and working a crappy coles job it takes a bit haha.
got a shed at my girlfriends to fix it in. just need the know how and the moolah
sierra manual here i come !
Post Posted: Fri Apr 22, 2011 10:59 pm
Easy fix mate - bearing kits from Ebay and just follow the manual - Have fun - Tony
Vehicle: 2018 DMAX
Post Posted: Fri Apr 22, 2011 11:04 pm
I got my carrier bearings from weaves for under $15 each, probally cheaper going that way id think...
Post Posted: Fri Apr 22, 2011 11:54 pm
the manual that comes with it or the Haynes Sierra Manual??
thats the way im going to do it for sure.
cheers guys
Post Posted: Fri Apr 22, 2011 11:55 pm
cheers guys
Post Posted: Sat Apr 23, 2011 12:01 am
any chance you can record the sound as a video and put it on youtube or something? mine makes a small click/clunk on clutch release also - i just thought it was my trac bar hitting the springs (which its designed to do) but would be worth knowing if it actually is my diff!
would jacking the rear end off the ground and turning the wheels by hand (with the locker engaged) replicate the click or does it need the weight of the car?
cheers guys
NOT a Haynes, Download the real workshop manual if you don't have one. Much better.
Post Posted: Sat Apr 23, 2011 1:09 am
Where do you download the real workshop manual from?
Post Posted: Sat Apr 23, 2011 1:14 am
just do them yourself mate. They aren't hard to do! Save ya lots of money!!!
Post Posted: Sat Apr 23, 2011 1:20 am
Shoud find something here.
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Sat Apr 23, 2011 3:22 am
Mine does the exact same thing!
Subi + Suzi = Best of both worlds!
Post Posted: Mon Apr 25, 2011 12:07 am
thanks heaps guys. going to have to take a stab at it i think =P
Post Posted: Mon Apr 25, 2011 1:39 am
mine does the same, mine started almost instantly after i got my rear auto locker installed so just put it down to that. if i release the clutch slowly it doesnt happen.
Post Posted: Mon Apr 25, 2011 1:44 am
maybe its a backlash thing?
Post Posted: Mon Apr 25, 2011 2:20 am
maybe but my R & P were not touched during the install, so doubt it. can you feel urs?
Post Posted: Mon Apr 25, 2011 2:21 am
i dunno... i'll go jack the ass end up and see.
Vehicle: 2004 SQ625 GV
Post Posted: Mon Apr 25, 2011 2:26 am
It is just your locker shandy. There is more backlash as the cross shafts take up slack in the locker. But do keep an eye on your uni's as they will flog out quicker with the locker fitted.
Post Posted: Mon Apr 25, 2011 2:28 am
nope... had the locker on and moved it back and forward rapidly and no clunks or anything of that nature... rear uni is brand new and driveshafts are full of grease... mine must be the trac bars, i can make them make noises by hand, must just sound different inside the cab.
Post Posted: Mon Apr 25, 2011 3:44 am
I hate to put a dampner on people giving things a go themselves but diffs are something that NEED to be right. If you haven't got the right tools it's probably cheaper in the long run to get someone who does know to do it.
Post Posted: Mon Apr 25, 2011 11:31 pm
yeah they said its backlash at one stop suzi.
yeah i know that. i would love to be able to just go in and give it to them to do
but im a student and work part time at coles so the cheaper option is going to have to do.
Users browsing this forum: Google [Bot] and 67 guests
