It is currently Mon Oct 19, 2026 5:47 pm
lesspostingmorewheeling
Post Posted: Sun May 18, 2008 2:23 am
This is probably a stupid question but is there an obivious way of telling a NT from a WT?
Mike
Post Posted: Sun May 18, 2008 2:31 am
yep! flares are skinnier & made of rubber, rear bar is narrower & don't have rubber ends bits... they are the first things that stand out for me anyway. oh & usually the grill and drum brakes is a giveaway
Post Posted: Sun May 18, 2008 2:37 am
so NTs have rubber flares? are NTs and WTs different models?
Post Posted: Sun May 18, 2008 3:07 am
The narrow track zooks have about a 1" wide rubber flare while the wide track models have metal flares which are about 2 1/2" wide (I think!) There are other notable differences between the 2 models; have a look at this article for a bit of background history (note that Samurai (USA) = Sierra (AUST)
http://suzuki.off-road.com/suzuki/artic ... ?id=277666
Post Posted: Sun May 18, 2008 3:24 am
thanks i didn't realise it was that easy to tell
Post Posted: Sun May 18, 2008 4:22 am
from a distance they all look the same, LOL
Post Posted: Sun May 18, 2008 2:24 pm
easiest way to tell is.............
year model ...88 onwards = WT
(wt flares can be fitted to nt)
also where the springs are mounted to the chassis..................
NT ..the springs are directly under the chassi
WT ..the springs are outboard of the chassis , about 50mm !!
if all else fails , back up & hit it again !!!!!
Users browsing this forum: Google [Bot] and 220 guests
