It is currently Tue Oct 20, 2026 10:06 am
Post Posted: Sun Apr 24, 2011 9:03 am
Hi all i'm looking at putting Power steering on my 95 Sierra, and would like some pics of the BenT powersteering wedge kit installed.
The reason i need pics is because i have welded my Bullbar Mounts onto the front chassis tube and need to know if this kit will still fit.
Also does my 1995 Sierra have a collapsable steering column?
and what belt do i need to run?
Conrad
I HATE CYCLISTS!!!
Post Posted: Sun Apr 24, 2011 9:21 am
The wedge shouldn't take up anymore room than the dimension of the base of the steering box if that makes sense? If a steering box fits now, which I assume it does, it should fit with a wedge. I have about a 5mm gap between wedge and chassis tube
Collapsable steering columns are a coily thing.
Belt size. Mine is a 830/4PK
Post Posted: Sun Apr 24, 2011 9:46 am
So they are good for something then
Post Posted: Sun Apr 24, 2011 9:51 am
WT's had them first. :wink:
Post Posted: Sun Apr 24, 2011 10:16 am
So does mine have a collabsable shaft or not, cos mine is a Wide Track or so i think it is.
How can i tell if it is collabsable? Just so i can check.
Conrad
I HATE CYCLISTS!!!
Vehicle: jimny
Post Posted: Sun Apr 24, 2011 10:19 am
its should have a rag joint shouldnt it?
Post Posted: Sun Apr 24, 2011 10:21 am
oh ok so the collabsable shaft wont have a rag joint or will it? Mine has a rag joint.
Conrad
I HATE CYCLISTS!!!
Post Posted: Sun Apr 24, 2011 10:32 am
They both have rag joints. A colapsable shaft is a 2 piece shaft, one fits tightly into the other with plastic pins holding it in place. The other version is a single piece shaft
Post Posted: Sun Apr 24, 2011 12:11 pm
92 onwards WT's had collapsible steering shaft.
Post Posted: Sun Apr 24, 2011 2:15 pm
So has any one actualy got a pic of the kit installed cause I've seen plenty of theads asking for pics but I've never actualy seen one
Post Posted: Sun Apr 24, 2011 7:32 pm
Learn something new everyday 8)
Post Posted: Sun Apr 24, 2011 7:40 pm
From Underneath
Front On
Please excuse half of the GH Mountains under my car still :oops: :oops:
Post Posted: Sun Apr 24, 2011 9:26 pm
You are only going to require the wedge itself and the bolts for it. I dont think think that the adapter for the pump is going to line up on your 1600. Do you have the baleno pump and bracketry?
Try contacting BenT and see if you can buy a half kit?
Post Posted: Sun Apr 24, 2011 9:44 pm
Your paying all the money for the wedge itself. The brackets and a couple of bolts are worth nothing compared to the machine time etc to mill the wedge from a single piece of metal :wink:
Post Posted: Sun Apr 24, 2011 9:47 pm
your radiator's looking a lil worse for wear Mr Trusho..... :helloo:
Post Posted: Sun Apr 24, 2011 10:25 pm
It's on the list of shit I need. Might hit Jas up to see if he has any :wink:
Post Posted: Sun Apr 24, 2011 10:32 pm
90 onwards Maruti's too...
Post Posted: Sun Apr 24, 2011 11:18 pm
I am using a vitara power steering setup. i will ask BenT about the setup for my baleno engine.
Conrad
I HATE CYCLISTS!!!
Post Posted: Sun Apr 24, 2011 11:20 pm
Rusho wrote:
From Underneath
Front On
Cheers Mate that really helps me out much appreciated.
I HATE CYCLISTS!!!
Vehicle: 85 SJ413
Post Posted: Mon Apr 25, 2011 5:06 am
Actually, even with the 1600, you still need the pump mount adaptor, as the pump position on the Vitara is right down low on the block, and in a Sierra the pulley will hit the radiator mount on the chassis.
If this radiator mount has been cut off the chassis to change to a different radiator etc, then you can get away without it.
The pump mount adaptor fits both the 1300 and the 1600.
I do sell just the wedge and bolts though for people with modified rad mounts / different engines etc.
Ben
Post Posted: Mon Apr 25, 2011 7:24 am
Ben
My zook has retained the stock 1.3 radiator, so will i need the bracket for this?
Conrad
I HATE CYCLISTS!!!
Vehicle: 85 SJ413
Post Posted: Mon Apr 25, 2011 7:42 am
Conrad
If you are using the Vitara pump, then yes, would need the complete kit including the pump mount bracket.
Its been a while since I've seen a Baleno pump and mounting bracket, so I'm not sure if the Baleno pump would fit and clear everything, and not require the pump mount bracket. I do remember they have a smaller pump, so may not have enough flow, although if I remember correctly they have a smaller pulley, so this may make up for it.
The best solution is probably to get the whole kit and use the Vit pump.
Ben
Vehicle: Nissan
Post Posted: Mon Apr 25, 2011 8:17 am
my 91 WT has a collapsible steering shaft :wink: :)
Pearce-toff Racing
Post Posted: Tue May 03, 2011 1:30 pm
Got my conversion kit from BenT, just waiting on my vitara powersteering parts.
The kit was well packed and def looks the goods BenT's work looks really good. Top Job bud.
Conrad
I HATE CYCLISTS!!!
Post Posted: Tue May 03, 2011 1:40 pm
My 91 swb wt had colapsable shaft
My 88 lwb wt did not. But does now due to ps conversion.
Drill the 4 plastic dowels 3mmish deep and hammer away. (if you need to extend or retract it) It will be very stiff because there is a big moulded plastic section in the middle moulded arount the shaft, inbetween the outer and inner shaft.
Post Posted: Sun Nov 12, 2017 10:04 am
Grave dig....but proves i searched. Baha
Where do the power steering lines run??? Any pics?
Users browsing this forum: No registered users and 235 guests
