It is currently Sat Nov 07, 2026 6:11 am
Post Posted: Tue Apr 26, 2011 7:50 am
I've got a cressida box in my sierra with an ea falcon tear drop pump. when you turn the steering, and let it go, the pump sounds like its loaded up. when you move the wheel a fraction either way noise goes. so whenever you stop and let it idle, you always have to move the wheel so it's not loading up.
The lines get really hot even after a minute. when driving after about 40mins it starts getting really loud all the time. tried another pump, same prob. it runs a small cooler under radiator.
Post Posted: Tue Apr 26, 2011 8:01 am
Oil level obviously right? Bled properly? What oil are you using? Have you tried removing the steering damper?
Post Posted: Tue Apr 26, 2011 8:06 am
yeah oil level spot on, no air in system. usind dextron3
was wondering if there's some sort of pressure releif valve in the box. that can be checked or tested
Post Posted: Tue Apr 26, 2011 8:07 am
Relief valve should be in the pump
Users browsing this forum: No registered users and 71 guests
