| Will I fit!? https://auszookers.com/forum/viewtopic.php?f=5&t=21386 |
Page 1 of 2 |
| Author: | pixelvandel [ Wed Apr 27, 2011 5:58 am ] |
| Post subject: | Will I fit!? |
Hey lads. I owned a swb Sierra a while back with a gti motor and some other bits and bobs.long story short, sold it. Miss it. Want another one haha. I've been trying to find a lwb, cos I need to cart some stuff Round nowadays, but I've found quite a nice lwb ute for sale, but I'm a tall bugger at 6'4.... Will I even fit in a regular ute cab? And how hard would it be to source a maruti style kingcab extention if not? Or rig up a hole in the back with a softtop style cover when it rains? Appreciate any input guys. Cheers! |
| Author: | zukmeista [ Wed Apr 27, 2011 6:09 am ] |
| Post subject: | Re: Will I fit!? |
From what I've heard, utes are very uncomfortable for tallish people |
| Author: | beerhound [ Wed Apr 27, 2011 6:16 am ] |
haha thank the gods for my height inpediment |
| Author: | Scrawny [ Wed Apr 27, 2011 6:25 am ] |
Fatzook has a ute and he ain't short! Don't expect to be in it for long periods. You'd be better off with a LWB soft top, at least you'd have more leg room then |
| Author: | SuziBlu [ Wed Apr 27, 2011 6:31 am ] |
I have a Maruti, im 6'3" an fit well. Drove it from Berri to Adelaide, then from Adelaide to home, bout a 10 hour run, was a bit cramped on that run, but no real issues. |
| Author: | pixelvandel [ Wed Apr 27, 2011 6:49 am ] |
Haha yeah I sat in a friends Darin 1200 ute and I had no headroom lol. I was thinking of maybe cutting the rear of the cab so I cab lean the seats right back and out, and making up a basic rubber sealed canvas softtop with button clips. Should be easy enough? Just a flat piece....ahhh. It's a offer too good to refuse for this little ute! |
| Author: | BlueSuzy [ Wed Apr 27, 2011 7:06 am ] |
Find a late model maruti. Will give you the space you need, OR go for a drive in the one you have seen, then judge. |
| Author: | Fatzook [ Wed Apr 27, 2011 7:26 am ] |
Yeah as scrawn said, I have a tin top ute. Very cosey Even with these two things done, maximum seat time is still 2-3 hrs. Thats not a problem for me. I am happy to get out after a few hrs to have a break and a stretch. |
| Author: | bohuler [ Wed Apr 27, 2011 7:28 am ] |
If you use enough lubrication, anything can be made to fit in anything Dave |
| Author: | Scrawny [ Wed Apr 27, 2011 7:31 am ] |
bohuler wrote: If you use enough lubrication, anything can be made to fit in anything
Dave Just because it can fit doesn't mean it's supposed to |
| Author: | mnemonix [ Wed Apr 27, 2011 7:56 am ] |
Marutis have SOO much more legroom than a regular tin top. I used to bludge a mates hard top '89 ute and drive it. Bloody cramped with legs fouling the steering wheel and I'm a short ass at 5' 7". I own a maruti and I drive with the seats several clicks forward because there is so much legroom. Got a mate who's 6"2' who drives it with no issues at all. |
| Author: | Fatzook [ Wed Apr 27, 2011 8:44 am ] |
mnemonix wrote: Marutis have SOO much more legroom than a regular tin top.
I used to bludge a mates hard top '89 ute and drive it. Bloody cramped with legs fouling the steering wheel and I'm a short ass at 5' 7". I own a maruti and I drive with the seats several clicks forward because there is so much legroom. Got a mate who's 6"2' who drives it with no issues at all. Agreed. I've owned a MAruti also, and the internal space is much larger. Still love my tin top though |
| Author: | SuziBlu [ Wed Apr 27, 2011 11:03 am ] |
I have a drover, soft top, can't say as their is any more room in either. |
| Author: | Fatzook [ Wed Apr 27, 2011 11:06 am ] |
The maruti uses the WT floorpan. With this you get sliding seat rails and the ability to shift the backrest of the seat well past the B-pillar. The tin top ute has fixed seats. No slides at all. The rear wall is some 50mm forward of the rear edge of the B-pillar, and the seat literally rest against the rear wall. Infact the OEM headrests are bolted to the rear wall of the cab. I'd estimate that there is more than 150mm extra leg room in a maruti over a tin top ute. Atleast! |
| Author: | SuziBlu [ Wed Apr 27, 2011 11:14 am ] |
ye gods, that would suck. Definitely too small. |
| Author: | Fatzook [ Wed Apr 27, 2011 11:22 am ] |
SuziBlu wrote: ye gods, that would suck. Definitely too small.
Yep. mm's to spare in every direction |
| Author: | stockman [ Wed Apr 27, 2011 1:00 pm ] |
BlueSuzy wrote: Find a late model maruti. Will give you the space you need, OR go for a drive in the one you have seen, then judge.
Bingo! |
| Author: | pixelvandel [ Thu Apr 28, 2011 6:55 am ] |
Problem is the one I'm interested is a few hours drive away! Haha. Anyone on the gold coast have a stockman I can hit up to go for a sit in?? |
| Author: | 303zuke [ Thu Apr 28, 2011 1:09 pm ] |
Fatzook wrote: The maruti uses the WT floorpan. With this you get sliding seat rails and the ability to shift the backrest of the seat well past the B-pillar.
The tin top ute has fixed seats. No slides at all. The rear wall is some 50mm forward of the rear edge of the B-pillar, and the seat literally rest against the rear wall. Infact the OEM headrests are bolted to the rear wall of the cab. I'd estimate that there is more than 150mm extra leg room in a maruti over a tin top ute. Atleast! The late 1.0 (type 3) and 1.3 hard top utes have the same floor fittings as the SWBs and LWB soft tops. Yes, the seats in the hard top utes are on fixed rails, but you can simply swap in sliding seat rails. You don't have the full amount of travel of the rail, but you do gain about 50mm of legroom. By removing the fixed Ute headrest, the complete WT seat will fit in allowing you to slide the seat further back, and also tilt it forward to store items behing the seats. I'm 6'4" also and used to fit snugly in my ute with WT Sierra seats. While not as good as Recaro's, they certainly made long trips bearable. An LJ81 though is simply torture for a taller person, much less room than a Sierra hard top Ute. Be on good terms with a Chiropractor! |
| Author: | Samwich [ Wed Jul 30, 2014 12:24 pm ] |
Hey guys, What seats will give the most room in a Tintop Tray back? im 6ft3... Fatzook hasnt replied to PM hahaha |
| Author: | Gwagensteve [ Wed Jul 30, 2014 12:27 pm ] |
A fixed back race seat like a Sparco Sprint. These are both upright and thin so you can get your back much closer to the back wall of the cab. A kirkey would probably be the best but their neither legal or practical for road use |
| Author: | Samwich [ Wed Jul 30, 2014 12:32 pm ] |
sounds very uncomfortable :/ ... Might have to get a smaller steering wheel aswell |
| Author: | Scrawny [ Wed Jul 30, 2014 12:44 pm ] |
Samwich wrote: Hey guys, What seats will give the most room in a Tintop Tray back? im 6ft3... Fatzook hasnt replied to PM hahaha Pete had these in his ute
| Author: | Samwich [ Wed Jul 30, 2014 12:48 pm ] |
They Recaro SE's? |
| Author: | Gwagensteve [ Wed Jul 30, 2014 12:50 pm ] |
Which would have to be the least space efficient seats ever. I have them in piggles and they soak up heaps of room. Scrawn- decent fixed back race seats are far more comfortable than most recliners, they're also good value because they're much cheaper to make than a recliner. Sit in a Sparco Sprint- you'll be surprised. Steve. |
| Author: | Samwich [ Wed Jul 30, 2014 12:59 pm ] |
Cheers Steve, Ill have to find one for sale and go check it out Much work needed on the rails? or just the usual cut+ weld to fit |
| Author: | Gwagensteve [ Wed Jul 30, 2014 1:13 pm ] |
Not hard at all. I made fixed rails for piggles, drivers to suit my stumpy legs, passengers with the seat all the way back. If required, it only takes 5 minutes to swap left and right to suit a taller driver. This was only because utes don't come stock with sliding rails. My SE Recaros are on recaro sliding rails. One of the problems with the Recaros for a tall driver is that the squab is quite thick, which sits the driver up high. Steve. |
| Author: | Samwich [ Wed Jul 30, 2014 1:19 pm ] |
Sounds like the way to go, Are there any seats that arent full "Buckets" but have the same sort of profile as the Recaro Sprints? (Im a lil wider aswell) hahahaha I have sat in a race seat in my old race gemini and fitted fine. But was shit for longer periods... |
| Author: | Gwagensteve [ Wed Jul 30, 2014 1:40 pm ] |
Sparco sprints are pretty wide- they're much wider than most race seats. I think there are wider versions available too. Look for "XL" in the model name. Recaro's fixed back seats are generally very tight (as race seats should be) and come in three widths, but I've tried the Fixed back recaro off road and it's too tight to be practical for recreational use. |
| Author: | Scrawny [ Wed Jul 30, 2014 1:52 pm ] |
Gwagensteve wrote: Scrawn- decent fixed back race seats are far more comfortable than most recliners, they're also good value because they're much cheaper to make than a recliner. Sit in a Sparco Sprint- you'll be surprised. Steve. No arguments there! Unfortunately, fixed back seats aren't practical for most applications, especially if you have a gf or other females needing to drive occasionally. I do like the look of these seats tho!
