| G16A normal temp https://auszookers.com/forum/viewtopic.php?f=5&t=21409 |
| Author: | sbbunno [ Thu Apr 28, 2011 2:37 am ] |
| Post subject: | G16A normal temp |
hey guys just finished my g16A conversion and noticed that it runs hoter than g13A (which i expected) but might be little too hot for a hot day on the beach, was wondering what you guys have done for extra cooling? the temp guage sits around half. cheers |
| Author: | zooky08 [ Thu Apr 28, 2011 2:47 am ] |
| Post subject: | Re: G16A normal temp |
Half is fine I think Mine sits on 3/4 but I don't worry about it If u want extra cooling try a thermal fan Or a bigger radiator |
| Author: | tanshi [ Thu Apr 28, 2011 2:55 am ] |
My g16a didnt run any hotter that my g13. Maybe get your cooling system checked and cleaned? |
| Author: | sbbunno [ Thu Apr 28, 2011 2:56 am ] |
yea got a thermo fan. i took it up a few tracks the other day and the temp didnt change at all, the ones on lowrange will they do the trick, |
| Author: | royce [ Thu Apr 28, 2011 2:59 am ] |
did you put the 1300 temp sender into teh 1600? |
| Author: | Reubs [ Thu Apr 28, 2011 3:02 am ] |
In both my coilies (1 is G13, 1 is G16) both guages sit in exactly the same spot (just under halfway) at operating temp. If I had just done a conversion the I would assume a different reading on the guage would be due to differences in thermostats or temperature senders. The stock Sierra radiator is easily big enough for a G16 if it is in good condition. |
| Author: | JrZook [ Thu Apr 28, 2011 3:22 am ] |
Reubs wrote: The stock Sierra radiator is easily big enough for a G16 if it is in good condition.
Agreed!! |
| Author: | sbbunno [ Thu Apr 28, 2011 3:27 am ] |
ok i didnt realise that i should switch the temp sender unit, well in that case all should be good. |
| Author: | Poita [ Thu Apr 28, 2011 4:10 am ] |
Where do people get their thermo fans from? |
| Author: | sbbunno [ Thu Apr 28, 2011 4:35 am ] |
me and a mate got ours from a local auto shop |
