It is currently Fri Nov 06, 2026 1:10 pm
Post Posted: Thu Apr 28, 2011 6:59 am
hi i am getting my 1.6 sohc efi rebuilt. can anyone tell me a good combo for a long motor. running around 8 pound boost. thanks all.
Post Posted: Thu Apr 28, 2011 7:11 am
Who's doing your tuning? they might have some ideas for you.
With 8lb you should be able to run the stock compression. A good intercooler and good fuel will most likely be necessary.
Post Posted: Thu Apr 28, 2011 7:17 am
the motor will be decompressed. and allready have intercooler and tunded to 4 pound. just need strong internal setup to run higher boost and be reliably. thanks damo
Post Posted: Thu Apr 28, 2011 10:37 am
What pistons & rods are you going to use? How did you lower the compression?
Post Posted: Thu Apr 28, 2011 10:38 am
the vitara's have low compression any way mate, thats why the guys with turbo GTI swift use the vitara pistons you should be good up to id say 10-12 psi and even higher if you double the head gasket. I had a turbo GTI with forged vitara pistons an ran 42PSI on the stip.
Post Posted: Thu Apr 28, 2011 10:48 am
Nagz wrote:
blah blah blah, I had a turbo GTI with forged vitara pistons an ran 42PSI on the stip.
did you get more than one pass out of it?
Post Posted: Thu Apr 28, 2011 11:26 am
thanks guys but ive been told 6psi is max for stock vitara 1.6. all i need is a list of strong internals for my motor builder because he is having trouble finding it in perth. thanks again
Vehicle: LWB Sierra & XL7
Post Posted: Thu Apr 28, 2011 11:51 am
A decent engine builder SHOULD know all the contacts for the items and resources he needs.
Wiseco or Arias would have forged pistons to suit. I've read standard pistons will cope with relativly low boost of 6psi, so ACL pistons are good replacements.
Of course like with any rebuild the bores should be honed, the crank re-balanced and for optimum performance, the head should be rebuilt with a new or reground cam, 3 angle valve job with new valves, might as well match-port the inlet and exhaust ports.
'92 Vitara & Camper trailer
Post Posted: Thu Apr 28, 2011 8:18 pm
sure did bro, lasted a good 8 runs :? spend way way to much money to be able to do that tho (stupid 19yr old i was)
boost was at 22 psi on the street
Users browsing this forum: Google [Bot] and 59 guests
