It is currently Sat Aug 01, 2026 10:19 am
Post Posted: Thu May 05, 2011 3:43 am
fitted the new loom in got most of it sorted but now i only have low beam no high beam what so ever no idicators my tacho is not working has anyone got any ideas i have checked the main things such as fuses, power to the head lights.
should also add it does not have the factory carbie on there either its got the holley 180.
any ideas would be great thanks
Post Posted: Thu May 05, 2011 3:51 am
what happens when you switch to High Beam?
sorry to say it but electrical stuff sucks and people arent going to try and help unless you can be very detailed in whats happening
Post Posted: Thu May 05, 2011 3:58 am
ill try to explain better sorry royce...
low beam work as soon as you hit high beam either way on the combo switch no lights what so ever...
Vehicle: 03 Jimny
Post Posted: Thu May 05, 2011 4:06 am
Check your relays
Post Posted: Thu May 05, 2011 4:34 am
ok if the lights turn off the high beam wire is either cut or unplugged or the switch is burnt out
have a look at the plug on the back of the headlight (leave them plugged in), the right hand vertical pin is the high beam wire, note its colour and go looking for the same colour wire in teh big plug under the column that goes up to the headlight switch.
Now get your test light and put the clip onto an earth somewhere and probe that wire and see if the test light lights up and report back
Also just to be sure, pull the 3rd and 4th from the left in the top row fuse out and look at them to see if its blown.
Post Posted: Thu May 05, 2011 5:28 am
I just did what you said to do Royce there is power going to all the pins on the switch plug and headlight plugs but no I only have tail light checked and replaced the fuses but still nothing could it be the switch itself
Post Posted: Thu May 05, 2011 8:00 am
no, I only wanted you to check 1 wire, the wire that matches the pin I said on the headlight plug, tell me what happens there
Post Posted: Thu May 05, 2011 10:05 am
Oh ok sorry the was power at the headlight plug I changed the bulbs to just to make sure but still nothing
Vehicle: Jeep
Post Posted: Thu May 05, 2011 6:16 pm
Are the headlights bright or dim when they are on ?
I may be wrong, but it sounds to me like most of the electrical problems you describe, stem from a bad Negative connection in the wiring somewhere... :D
Post Posted: Thu May 05, 2011 6:25 pm
Lol it could be faulty globes
Post Posted: Thu May 05, 2011 9:00 pm
Please keep out of the fault finding process if you dont know what you are talking about, youll jsut confuse him :wink:
if the headlights work on low we can assume the common power supply to both beams is fine and the earth from the dip switch is ok, leaving only the earth switching circuit for the high beam, hence my request to find the high beam wire at the column and see if it has power, this will tell us if there is continuity from the high beam terminal on the lights to the switch, then we can start looking at the switch or the wiring.
Users browsing this forum: Google [Bot] and 342 guests
