It is currently Sun Oct 18, 2026 10:33 pm
Post Posted: Thu May 29, 2008 2:25 pm
Does anyone have a g16 crank pulley handy? (the one that runs a serpantine belt) I need to know what the dia of the g16 one is.
Post Posted: Thu May 29, 2008 4:15 pm
what point do you want to measure from?
Post Posted: Thu May 29, 2008 4:32 pm
If you look at the pulley (ascii art below) from the side you can see the grooves for the belt. I guess if you measure from the apex of one of those (eg, the '/\' bit) to the same on the other side. If I do the same on the other pulley I have I should be able to calculate the drive ratio.
Post Posted: Thu May 29, 2008 5:28 pm
when calculating drive ratios do you need to take the mean diameter? ie from middle of the valley to middle of the valley?
Web wheeler extroadinaire
Post Posted: Thu May 29, 2008 6:52 pm
Dunno. If the height is the same on both pulleys it shouldn't matter. Might do some sniffing around and see what I can find out.
Post Posted: Thu May 29, 2008 9:44 pm
Found an online calculator http://www.csgnetwork.com/pulleybeltcalc.html
Post Posted: Thu May 29, 2008 11:01 pm
As best as i could measure its 130mm.
92 WT softback ute, twin lockrights, 3.9 diffs, S1
Users browsing this forum: No registered users and 221 guests
