https://auszookers.com/forum/
g16 crank pulley diameter
https://auszookers.com/forum/viewtopic.php?f=5&t=2188
Author:  Damo [ Thu May 29, 2008 2:25 pm ]
Post subject:  g16 crank pulley diameter
Does anyone have a g16 crank pulley handy? (the one that runs a serpantine belt) I need to know what the dia of the g16 one is.
Author:  royce [ Thu May 29, 2008 4:15 pm ]
Post subject:  Re: g16 crank pulley diameter
what point do you want to measure from?
Author:  Damo [ Thu May 29, 2008 4:32 pm ]
If you look at the pulley (ascii art below) from the side you can see the grooves for the belt. I guess if you measure from the apex of one of those (eg, the '/\' bit) to the same on the other side. If I do the same on the other pulley I have I should be able to calculate the drive ratio.
Author:  Pubic [ Thu May 29, 2008 5:28 pm ]
when calculating drive ratios do you need to take the mean diameter? ie from middle of the valley to middle of the valley?
Author:  Damo [ Thu May 29, 2008 6:52 pm ]
Dunno. If the height is the same on both pulleys it shouldn't matter. Might do some sniffing around and see what I can find out.
Author:  Damo [ Thu May 29, 2008 9:44 pm ]
Found an online calculator http://www.csgnetwork.com/pulleybeltcalc.html
Author:  neil_se [ Thu May 29, 2008 11:01 pm ]
As best as i could measure its 130mm.
