| Author |
Message |
lumpy_zook
Joined: Thu Jan 27, 2011 2:15 am Posts: 108 Location: whyalla
 Posted: Wed May 11, 2011 2:07 pm |
basically, im trying to decide between them.
car will be mainly used as offroad fun, 1.6 vit conversion, power trax rear auto locker already.
question is.. will welding up the gaps in the side gears and spider gears, so they are all separate still, but cant rotate, be a feesable option?
or should i just buy another auto locker without the couplers for the front?
please no auto lock hate.. dont really care if airlockers are better. need cheap budget options.
thanks!
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Wed May 11, 2011 2:25 pm |
I would go for the lockright, welded front sucks in every thing exept for very soft mud
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
lumpy_zook
 Posted: Wed May 11, 2011 2:30 pm |
no worries. thanks mate.
auto locker it is!
brent
Joined: Sun Dec 13, 2009 10:30 pm Posts: 94 Location: QLD- WIDE BAY
 Posted: Wed May 11, 2011 8:27 pm |
Yeah go with the auto locker.. Im twin locked and there is nothing wrong with them at all. I really don't understand all the hate for them..
christover1
 Posted: Wed May 11, 2011 10:38 pm |
I got away with a welded front for years in my Sierra.
I just opened one hub until 4wd was needed.
Was a bit heavy down steep hills, but fitting power steering solved that.
Then I scored a front lockrite cheap for it, and was much happier with that.
Power steer still makes an autop locker better to handle.
My Vit has auto lockers both ends, very happy with it.
christover
3cyl
Joined: Tue Jan 29, 2008 10:30 pm Posts: 2054 Location: Ipswich
 Posted: Thu May 12, 2011 7:17 am |
Only other cheap option for offroad is if you throw the Lockright in the front and weld the rear. I ran mine that way for a while but prefer 2 Lockrights.
_________________ awesome only comes in 2 colours, camo & bare metal
lumpy_zook
 Posted: Thu May 12, 2011 7:22 am |
yea, i was thinking of that way, but the lockright has the couplers so it wont fit into the front without the stronger axle kit (i think)
will just run it open front until i need to rebuild the front swivels and put a lock right in then. no point twin locking it when i havnt even pushed the stock set up at all...
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Thu May 12, 2011 7:40 am |
Correct - mini spool the rear and double tough the front with your lockright for about $350+shipping and have a set and forget driveline you'll struggle to break.
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Thu May 12, 2011 8:04 am |
lumpy_zook wrote: yea, i was thinking of that way, but the lockright has the couplers so it wont fit into the front without the stronger axle kit (i think)
you could just buy the lock right with new couplers and still use old ones till your ready ? to put the 26spline axles in ... am i wrong in saying this ?
lumpy_zook
 Posted: Thu May 12, 2011 8:50 am |
From the pictures of the power trax locker the coupler kit is different to the kit you use with the side gears.
The couPler ones are a flat ratchet surface, where as the side gear kit is tapered to mate to the gear face.
Not that bothered in the long run. It would be capable enough with no lockers with the terrain close to my town.
Only keen on twin lockers for flinders trips. :p
3cyl
 Posted: Thu May 12, 2011 9:32 am |
However you lock the front you'll be wanting the 26 spline front axles and CVs eventually.
dave91
Joined: Sun Mar 27, 2011 11:37 pm Posts: 411 Location: Brisbane
 Posted: Fri May 13, 2011 3:42 am |
what's an auto locker and a mini spool? i know about air lockers and all that but no one's given me the run down on how the others work.
_________________ Every problem can be solved with a Ratchet.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Fri May 13, 2011 3:48 am |
Auto locker is a spring loaded locker that ratchets when turning to give a similar effect to an open diff, but locked otherwise.
Spool joins the two axles together and is held in place by the cross pins.
_________________ mlm
dave91
 Posted: Fri May 13, 2011 4:07 am |
auto locker sounds alright, or am i wrong to think that?
SierraDan
 Posted: Fri May 13, 2011 4:20 am |
It's all opinion/situation based.
What jobs does your zook perform? Daily/Offroad 50/50? 80/20? 0/100?
dave91
 Posted: Fri May 13, 2011 11:16 am |
Well im still in the process of finding and buying a zook to modify, but i'd say 70/30 on road. But i want to make it into more serious off road car once i get my road bike registered.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri May 13, 2011 11:57 am |
weld over auto lockers any day
