| Hubs https://auszookers.com/forum/viewtopic.php?f=5&t=2211 |
| Author: | CTZOOK [ Sun Jun 01, 2008 10:39 pm ] |
| Post subject: | Hubs |
Having problems with hubs not locking in is it a simple fix or better to just replace. |
| Author: | royce [ Sun Jun 01, 2008 11:01 pm ] |
| Post subject: | Re: Hubs |
pull em off, clean it all up and regrease, put em back in, easy as |
| Author: | MUD-PIG [ Wed Jun 04, 2008 3:50 am ] |
Front dial comes of with 10mm socket
Take the circlip of around the axle on the inside, undo the outer hub bolts 12mm and pull it out clean it all up with degreaser. Pull the dial apart and clean around the seals and clean your spring up and put it all back together see how that goes really easy job.
| Author: | Brett [ Wed Jun 04, 2008 1:59 pm ] |
if you leave the circlip off you can pull the whole hub off to swap a cv when you break them. just make sure you bend the tabs back on the lock spacer. makes it a lot quicker and dont need to worry as much about the hub. just a thing if found out over time. |
