| starter motor https://auszookers.com/forum/viewtopic.php?f=5&t=2216 |
| Author: | Mike [ Mon Jun 02, 2008 5:02 am ] |
| Post subject: | starter motor |
Where is the best place(cheapest) to get a starter motor for a 1.3 sierra and how much would one cost? Cheers Mike |
| Author: | Bruce [ Mon Jun 02, 2008 12:19 pm ] |
| Post subject: | Re: starter motor |
Well that just depends where you live. |
| Author: | steve [ Mon Jun 02, 2008 12:32 pm ] |
i think "under down under" means Tasmania and you can't talk Brucie, you don't even have a location |
| Author: | terry [ Mon Jun 02, 2008 1:31 pm ] |
check ur phone book under wreckers if ur in tassie. if u tried that and had found nothing try www.suzisport.com that should help. |
| Author: | Mike [ Tue Jun 03, 2008 3:02 am ] |
Bruce wrote: Well that just depends where you live.
well i live in hobart but if i can find one cheap enough somewhere i'd just get it posted to me |
| Author: | Mike [ Tue Jun 03, 2008 3:04 am ] |
steve wrote: i think "under down under" means Tasmania
and you can't talk Brucie, you don't even have a location yep i live there but under down under sounds more interesting than just saying tassie |
| Author: | Mike [ Tue Jun 03, 2008 3:07 am ] |
terry wrote: check ur phone book under wreckers if ur in tassie. if u
tried that and had found nothing try www.suzisport.com that should help. it would be cheaper buying a whole sierra than buying a starter motor from a wreckers here suzisports is the only place other than repco that i've found so far that have them cheers |
| Author: | neil_se [ Tue Jun 03, 2008 11:50 am ] |
Can you get just the solenoid from anywhere cheaper, or another model eg.swift solenoid that fits? |
| Author: | BlueSuzy [ Tue Jun 03, 2008 11:12 pm ] |
i think the 1.3 swifts are a different starter alltogether? Quote me if im wrong. When my starter snapped the ratchet type shaft i found another started motor out of a 95 or earlier lancer if that helps, May be cheaper?.. My sierra starter is a Mitsubishi Brand, Where as swifts had another like Bosch or Denso or sumthing, cant remember. Hope it helps dude! |
| Author: | Mike [ Tue Jun 03, 2008 11:43 pm ] |
neil_se wrote: Can you get just the solenoid from anywhere cheaper, or another model eg.swift solenoid that fits?
its hard to get anything for suzukis here and i'm stuggling to just find the whole starter motor, so far the only place here i can find one is repco and don't get me to started on repco first they told me suzuki didn't make a 1.3 litre sierra in 1990 and they didn't believe me when i said i had one then when getting a price on a starter motor one minute it ws $210 and they had one then it was $350 and they would have to order one from bosch |
| Author: | Mike [ Tue Jun 03, 2008 11:45 pm ] |
BlueSuzy wrote: i think the 1.3 swifts are a different starter alltogether? Quote me if im wrong. When my starter snapped the ratchet type shaft i found another started motor out of a 95 or earlier lancer if that helps, May be cheaper?..
My sierra starter is a Mitsubishi Brand, Where as swifts had another like Bosch or Denso or sumthing, cant remember. Hope it helps dude! what model sierra is yours and do all have the same brand? Cheers |
| Author: | MUD-PIG [ Wed Jun 04, 2008 4:37 am ] |
Go directly to your Automotive electrical supplier thats what I did cut out the middle guys adding on their price in between. From the problems I had when getting a starter motor the different costs and prices came from the fact that I think the 1.6 starter also fits as well but its a longer motor where as the Sierra one is shorter. I have been given these two part numbers that fit both 1.3 and 1.6 when trying to sort out mine they both fit. 1300 part number M3T38981 or 31100-83010 - What I have in mine now, which is a 92 model Sierra. I went straight to 1600 part number M1T72481 or 31100-60A20 |
| Author: | Mike [ Wed Jun 04, 2008 4:56 am ] |
MUD-PIG wrote: Go directly to your Automotive electrical supplier thats what I did cut out the middle guys adding on their price in between. From the problems I had when getting a starter motor the different costs and prices came from the fact that I think the 1.6 starter also fits as well but its a longer motor where as the Sierra one is shorter.
I have been given these two part numbers that fit both 1.3 and 1.6 when trying to sort out mine they both fit. 1300 part number M3T38981 or 31100-83010 - What I have in mine now, which is a 92 model Sierra. I went straight to 1600 part number M1T72481 or 31100-60A20 do you know what brands these part numbers correspond with? |
| Author: | MUD-PIG [ Wed Jun 04, 2008 5:13 am ] |
Revolution Race gear I think.... Re manufactured stuff, either way parts shops have cross reference to check those part numbers are easy enough to look up. |
| Author: | Mike [ Wed Jun 04, 2008 5:19 am ] |
would you remember off the top of your head how much roughly was the reco starter? |
| Author: | MUD-PIG [ Wed Jun 04, 2008 7:39 am ] |
Ill try look back on my accounts or for a recipe but I think it was just over $200 or so... |
| Author: | BlueSuzy [ Wed Jun 04, 2008 8:29 pm ] |
i have a 91 1.3 wt sierra, starter was mitsubishi brand. Although i dont have the 1.3. i still use it in my 1.6 just machined down.... |
