It is currently Fri Nov 06, 2026 8:38 pm
Post Posted: Thu Jun 02, 2011 7:09 am
hi guys. just got a sierra. meant to have reduction gears. pretty sure it does based on the way it goes in low range but wanna check with you guys.
car has 31 inch mud tyres.
if i put it in 4wd low in 1st and second i dont think the speedo even moves. in 4th in low range it does a max speed of 30kmh. even at 7000rpm its only doing 30kmh.
so does it sound like crawler gears. meant to be the 6.1 or something gears.
or is it maybe normal or possible its got the 1l transfer case?
its a 1990 1.3 litre wide track.
thanks guys
Post Posted: Thu Jun 02, 2011 7:16 am
yea sound reduced to me. my stock gearing is crap in low range. can do like 20kmh in 1st. got 6.5's on the way tho :D
transfer gears will change high range too. 31's would be bad without them
Post Posted: Thu Jun 02, 2011 7:19 am
Yup Thats Def 6.5s for ya :) gota love them or hate them :)
Post Posted: Thu Jun 02, 2011 7:40 am
speedo wont move in 2nd low with 5.14 either ;) i guess another way is to turn the input shaft and count the output shaft (or vice versa) of the tcase. done this on my dads to discover it has 5.1's from our guess haha
Vehicle: 75 Cruiser
Post Posted: Thu Jun 02, 2011 7:52 am
if it had a standard case you'd be doing 80kph in low 4, take the crawler gears out, you'll never be able to race it like that :crazy:
:lol:
Post Posted: Thu Jun 02, 2011 7:54 am
thanks guys. im happy now. dont really care what ratio they are aslong as they are reduction gears as that and the front and rear lockers are the reason i bought the car
Post Posted: Fri Jun 03, 2011 2:21 am
this is what I did to mine to check if it had 6.5 - which it did :)
Put gearbox in neutral... Hubs unlocked... Transfer in 4lo
If you have an open rear diff you can jack up one rear wheel and support with an axle stand
Then turn the shafts to count the ratio....No need to remove any bolts.
Users browsing this forum: No registered users and 73 guests
