It is currently Mon Oct 19, 2026 10:38 pm
Post Posted: Fri Jun 13, 2008 3:48 am
average fuel consumption?
expected engine life?
availabilty of parts and upgrades for lift, engine, and accesories.
common problems and things to look out for before buying?
thanks for your help fellas.
Kyle
Post Posted: Fri Jun 13, 2008 3:53 am
hmmm
1. when i had my 93 jx wagon (1.6 injected) i got around 10l/100km
2. not too sure anbout engine life....but if looked after i would say it will last ages
3. aftermarket parts fairly well available here and in the US
4. not too sure.............i never had any problems with mine maybe some of the other guys could help with that
333...................im only half evil
Post Posted: Fri Jun 13, 2008 10:56 am
I get 9/100km in a swb with 235's, some get 12's
100000 to 300000 depending on how its looked after and driven, I have 230000 with no oil use at all
lots of suspension upgrades, few engine upgrades that are dear, bugger all accesories due to age, most people make their own
not common by any length but if they rust its in the bottom of the chassis rails under the footwells, some also suffer loss of power from the bottom pulley bolt working loose but its pretty hard to check without pulling it apart
Post Posted: Fri Jun 13, 2008 2:34 pm
looking at the 70kw engined 91 with 310thou k's....... so cant imagine fuel would be anything like a swb.... unfortunatly
Post Posted: Fri Jun 13, 2008 9:28 pm
8 to 10 L per 100, depends how you drive it.
My Carby G16B has 220,000 no oil use heeps of grunt.
No problems here heaps of accessories & parts avalible.
Oil seals front & rear leaking due to blow back, this can be because the breather on top of the rocker cover is blocked with crap.
Rust in foot wells & under drivers seat where jack is, mainly on soft tops.
Cracked exhaust manifold very common but not detrimental.
Over all great little 4WD and more compfy than a Sierra. Good on fuel and very capable off road & on the beach. Cheap parts and lots of fun..
BUY ONE NOW! :mrgreen:
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Sat Jun 14, 2008 7:38 pm
My 93 is great..
I get around the 8-10litre per 100k's.. Highway Speed :110kph @3600rpm
Acceleration whilst not being sporty, is not exactly slow either.
It wont win you any street light drags..
Driving in High wind can be a tad discomforting.. but is to be expected since your driving around in a car with a HUGE side profile and narrow wheel base..
310.000k's is a Little High.. I would be checking the usual stuff like timing belts and service intervals..
If it has been regularly serviced, then I would expect a major rebuild at the 360.000k point..
How much you are paying will be the deal clencher...
I know there are a few around the $3000-4500 price point with lower k's then 310.000k's
Post Posted: Sat Jun 14, 2008 8:17 pm
it needs a clutch and major service, has 1inch spring lift and not the cleanest thing.. will need a front right gard to look any good. asking 2G as is
