Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
bobbie88
Joined: Fri May 25, 2007 11:30 pm Posts: 39 Location: Bris Vegas, Ferny Hi
 Posted: Sat Jun 14, 2008 11:12 pm |
Hay guys, just wondering if anyone could tell me where the clutch adjustment is on the vitara lwb 1.6 injected and what would be the best way of doing it
cheers
Craig
royce
 Posted: Sat Jun 14, 2008 11:16 pm |
I could but you would probably call me spunky or something and scar me for life
bobbie88
 Posted: Sat Jun 14, 2008 11:25 pm |
lol thanks for the info the other day aswell, it was my brother that wrote that reply not me sorry bud.. lol
my car is now running fine, where the first spark plug goes into the block it was a tad wet, so i dryed it up and took her for a run and she is runnin sweet, the only thing that confused me, was she ran fine when cold but as soon as she warmed up it started playing, up any explaination?
Also is the lutch adjusting diffucult
royce
 Posted: Sat Jun 14, 2008 11:34 pm |
warm = leaner mix = harder to spark = more likely to seek other way
plus the water would steam up and rise into the boot
clutch is easy, get underneath and look for about 2-3mm play at the end of the clutch arm on the box, adjust the nut on the end of the cable till you get that
bobbie88
 Posted: Sat Jun 14, 2008 11:43 pm |
the reason i am adjusting the clutch is coz my gearbox is getting harder to select gears, well since Frasier and im think maybe the adjusment may have loosened or somehting coz the friction point is really close to the floor
i was thinking of doing gearbox oils and diff oils soon, do u think i should do these first before playing with the adjustment, also does low gearbox oil affect gear changes? sorry for the noobish questions
royce
 Posted: Sat Jun 14, 2008 11:46 pm |
if the pedal is low its worth looking at it, you will have to screw the but in a bit
oil is worth doing, they always shift better
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 247 guests
