| Starter problem https://auszookers.com/forum/viewtopic.php?f=5&t=22866 |
| Author: | rwicks10 [ Wed Jun 15, 2011 1:17 am ] |
| Post subject: | Starter problem |
Hey there! Does anyone else think that this is a little suspect? I took my vehicle down to Kmart Auto this morning to have the tires rotated. When I picked the vehicle up the mechanic informed me that he had had trouble starting my vehicle due to the solenoid on the starter motor. After I had payed for the work I went to leave, however I was unable to start my car. I have never had a trouble starting the vehicle up until this point. The vehicle is a SV420. With a tap of the solenoid, I was able to get it going. Do you think it is just bad luck or does anyone else think this is a little suspect? I am now looking at around $250 to have the starter out and the brushes replaced. Thanks for your time, rwicks10 |
| Author: | S13RR4 [ Wed Jun 15, 2011 1:19 am ] |
| Post subject: | Re: Is this a little suspect? |
If your mechanically minded the bushes cost around $11 for my brothers hilux starter, we pulled it apart and replaced them, piece of cake. |
| Author: | Rossco [ Wed Jun 15, 2011 3:05 am ] |
just open it up, use some wd40 and a light sanding. grease the arm from the solenoid into the starter motor and you should be fine. or as said above, there's nothing complicated inside. |
| Author: | JrZook [ Wed Jun 15, 2011 3:08 am ] |
S13RR4 wrote: If your mechanically minded the bushes cost around $11 for my brothers hilux starter, we pulled it apart and replaced them, piece of cake.
Solenoid of starter has no bushes.... OP just do as Rossco suggested. |
| Author: | stockman [ Wed Jun 15, 2011 3:08 am ] |
This may be of use: http://www.auszookers.com/index.php?nam ... ic&t=21965 |
| Author: | S13RR4 [ Wed Jun 15, 2011 3:19 am ] |
JrZook wrote: S13RR4 wrote: If your mechanically minded the bushes cost around $11 for my brothers hilux starter, we pulled it apart and replaced them, piece of cake. Solenoid of starter has no bushes.... OP just do as Rossco suggested. brushes? |
| Author: | JrZook [ Wed Jun 15, 2011 3:35 am ] |
S13RR4 wrote: JrZook wrote: S13RR4 wrote: If your mechanically minded the bushes cost around $11 for my brothers hilux starter, we pulled it apart and replaced them, piece of cake. Solenoid of starter has no bushes.... OP just do as Rossco suggested. brushes? Brushes are in the actual starter motor not the solenoid. |
| Author: | S13RR4 [ Wed Jun 15, 2011 4:14 am ] |
o my bad, dude said it would cost him $250 to have starter pulled out and brushes replaced and I remember replacing my brothers brushes for $11. must have read it wrong |
| Author: | Brenno [ Wed Jun 15, 2011 4:35 am ] |
If he went to Kmart auto to get his tyres rotated, I am not sure if he would have the mechanical ability to pull down a starter motor, regardless of how easy we know it is. (no offence) Starters can start playing up in an instant, I doubt they buggered around with anythning on you. |
| Author: | royce [ Wed Jun 15, 2011 4:41 am ] |
check its not something stupid like a loose or dirty terminal before you go pulling stuff apart |
| Author: | S13RR4 [ Thu Jun 16, 2011 12:13 am ] |
Brenno wrote: If he went to Kmart auto to get his tyres rotated, I am not sure if he would have the mechanical ability to pull down a starter motor, regardless of how easy we know it is. (no offence)
Starters can start playing up in an instant, I doubt they buggered around with anythning on you. well I don't know about you but whenever I put tyres on the front of my car I make sure they are balanced correctly. and I certainty don't have a wheel balance machine at home |
| Author: | Brenno [ Thu Jun 16, 2011 3:37 am ] |
S13RR4 wrote: Brenno wrote: If he went to Kmart auto to get his tyres rotated, I am not sure if he would have the mechanical ability to pull down a starter motor, regardless of how easy we know it is. (no offence) Starters can start playing up in an instant, I doubt they buggered around with anythning on you. well I don't know about you but whenever I put tyres on the front of my car I make sure they are balanced correctly. and I certainty don't have a wheel balance machine at home I was assuming that the tyre including rim was swapped, not removing tyre from rim, thus no need for rebalancing... |
| Author: | 31zook [ Thu Jun 16, 2011 6:47 am ] |
royce wrote: check its not something stupid like a loose or dirty terminal before you go pulling stuff apart
don't do that, just pull it apart |
| Author: | rwicks10 [ Fri Jun 17, 2011 9:59 am ] |
Thanks for the assistance their! I ended up getting the starter rebuilt by a local auto electrician. Cost a little, however the rebuild was significantly was cheaper than purchasing a new starter. All is good now, and it is back on the road. Cheers, rwicks10. |
