It is currently Fri Nov 06, 2026 6:42 pm
Post Posted: Thu Jun 16, 2011 10:03 am
Hey guys about to embark on a lux diff conversion on the missus's comp zook wanting to coil the rear anyone got any advice on the best setup I thinking a 3 link with panhard? Gunna stay with leaves in the front cause the zooks running a Holden 253 v8 has anyone put Ifs Lux leaves in a
Zook how hard is it?
Post Posted: Thu Jun 16, 2011 10:11 am
Make sure you retain enough roll stiffness in the rear. 3 links have no roll stiffness inherently and that will turn that 253 into a huge pendulum once the front goes light. That's why my rear end is radius arm at the moment - doesn't have hektic flex, but it doesn't axlewrap or hop and makes the front springs work due to the roll stiffness.
Post Posted: Thu Jun 16, 2011 10:40 am
I have a full set of p38 range rover Radius Arms Available if your interested
Brought them for a coil conversion on my Sierra
F#%ING [P] PLATER
 Profile YIM
Post Posted: Thu Jun 16, 2011 11:03 am
I'd go triangulated 4 link for the rear. Forget the panhard.
Post Posted: Thu Jun 16, 2011 11:16 pm
I have ome 40mm lux fronts in mine. I used these, because i wanted to keep the chassis extension as small as possible, and push the diff way forward. the frame was cut right behind the radiator mounts and extended about 250mm past stock.
[img][IMG]http://i45.photobucket.com/albums/f90/ridge88/P3190082.jpg[/img][/img]
this guy is using lux rears in front too
Post Posted: Fri Jun 17, 2011 12:53 am
wht about a rear Prado diff? is not the same as the hilux?.. with the adding that already comes with the coil setup
Vehicle: Work van
Post Posted: Fri Jun 17, 2011 2:09 am
BertZook wrote:
wht about a rear Surf diff? is not the same as the hilux?.. with the adding that already comes with the coil setup
Fixed :helloo:
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Fri Jun 17, 2011 5:15 am
Image[/quote]
Does anyone have a link to the build thread of this zook
F#%ING [P] PLATER
 Profile YIM
Post Posted: Fri Jun 17, 2011 9:48 am
sorry forgot to link it earlier, this is the new owners thread http://www.zukikrawlers.com/showthread.php?t=34410
and this is the old one
http://www.zukikrawlers.com/showthread. ... iwilson%2A
Users browsing this forum: Google [Bot] and 56 guests
